Results 1 to 14 of 14
Thread: 2016 R1200RT. disconnecting battery question:
    Apr 2017
    Cooperstown NY
    I just got a First Gear heated jacket. Instructions say to connect to battery...(ie can't use outlet or charging pigtail). Is it OK to just disconnect the battery and connect jacket cable, or is there a procedure I need to follow so as to not confuse the electronics on the bike? Oh- as long as I'm asking....where's the battery? (yeah, I could find it, but as long as I'm here...asking...)
    Thanks in advance guys!
    Quote Originally Posted by rick601 View Post
    Yes it can be connected to the battery which is accessed on the right hand side of the bike behind a triangular piece of body work just below the front seat. I installed a BMW outlet on the left side of my bike for use as a charging port as well as for my heated gear.
    Registered User gsinnc's Avatar
    Charlotte, NC
    I can understand why they suggest not using the OEM factory outlet but not understanding why the pigtail would not work? My dealer puts a heated gear / batter tender cable on all bikes they sell.
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2012 R1200GSA Magma Red!
    2016 R1200RT- Platinum Bronze
    Mar 2011
    socal
    Quote Originally Posted by rhaines View Post
    I did the exact thing on my bike, only opposite right side, on my buddies bike I installed it on upper fairing next to factory plug on right, just order the longer pigtails on powerlet plug, great for heated gear, air compressor and charging
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by gsinnc View Post
    not understanding why the pigtail would not work? .
    Same here.
    On my 2016 I use a pigtail connected to the battery for charging and heated gear.
    There's a remote positive post with a red cap on the right side of my bike making it easier to add a pigtail.
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    As others have written, the battery is on the right hand side, bellow the seat.
    There should be no problem with the electronics, as long as you do it in proper order. First, disconnect the ground (negative) from the battery, to prevent shorts to ground.
    There is a positive connector next to the battery that you can use instead of the positive pole.
    Reconnect everything in the reverse order.
    You may get an error code on the display. Reset the bike's clock to clear it. If you have the bike set to sync using the GPS, it will reset automatically.
    Someone posted this pic in the past, it's one of the best I've seen.
    Pat
    Ride Safe!
    '16 RT
    Apr 2017
    Cooperstown NY
    Quote Originally Posted by patm View Post
    Thanks, perfect!
    Quote Originally Posted by t6pilot View Post
    I have Gerbing's heated gear and the plug-in is on the left side of the jacket so the left side was the logical place to locate the power outlet.
    Mar 2011
    socal
    Ed
    Nothing wrong with using pigtail, my dealer also does that
    I just find it easier to use powerlet plug as all the gear I plug into it has the male Bmw/din connector
    Charlotte, NC
    Ed
    I just find it easier to use power let plug as all the gear I plug into it has the male Bmw/din connector
    My question was based on the OP comment that ...instructions say to connect to battery...(i.e. can't use outlet or charging pigtail)
    I understand using the BMW plug was just unsure why the instructions say no pigtail?
    Ed Apelian
    Apr 2017
    Cooperstown NY
    That's what it said! Though my dealer DID give me a connector for from charging pigtail (SAE?) to heated clothing stuff. Perhaps too many fuses? in a row?charger, and clothing . I did do a seperate connection with the first gear cable to battery , the plug tucks unobtrusively along seat, and controller velcroix to between tank bag straps.
    I am willing to bet that the clothing came with wiring with ring connectors on one end and a coaxial connector on the other end, with a fuse in the middle on the +12v wire. And that the instructions said, or intended to say, connect this directly to the battery. I do know that this is what happens with Gerbing and Warm and Safe.
    Charlotte, NC
    +1
    Ed Apelian
    Apr 2017
    Cooperstown NY
    Indeed the "First Gear clothing's heat is actually warm and safe hardware!" If by "ring" connector you mean red and black wires for direct battery connection- that too. The dealer did provide an sae to heater controller "jack" so I could plug to the tender cable, but I opted to follow the warm and safe/first gear instructions...if anyone is interested in the SAE tender connection to heat controller jack, part number I can look for it and post it.
  1. 2016 RRT Battery Cover
    By dabubba in forum Wetheads
    Last Post: 04-16-2017, 04:41 AM
  2. BMW battery charger question - 2006 R1200RT
    By Leo in forum Hexheads/Camheads
    Last Post: 12-24-2013, 10:24 PM
  3. Question on using a Deltran battery tender on a 2008 R1200RT
    By lfranklin in forum Hexheads/Camheads
    Last Post: 04-26-2012, 04:22 PM
  4. New Battery Question '09 R1200RT
    By DENKAR55 in forum Hexheads/Camheads
    Last Post: 03-03-2012, 04:19 PM
  5. Disconnecting the accessory socket
    By fracture in forum Hexheads/Camheads
    Last Post: 02-17-2009, 03:30 PM
