Results 1 to 9 of 9
Thread: Oil Filter Access Cover O-Ring
    Dec 2013
    Van Horne, Iowa
    Changed Engine oil and Filter on the 08 LT because Winter is Knocking on the door once again, so the next day I have a small oil leak near the cover in the pan.
    Does anyone suggest replacing the o-ring at certain intervals? Thought maybe I had some debris of some sort making it leak, try to be very careful about that.
    Thanks for any Suggestions, Donn
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    O-rings are not a lifetime part. Heat and being compressed cause them to loose their sealing capability. Not a bad idea to change every few oil changes.
    $3.45 from BMW.
    5 for $10 from beemerboneyard.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    $3.45 from BMW.
    I agree. I change them every 50K or so.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Just remember, 50k on Paul's bike happens WAY sooner than on most peoples bikes and doesn't allow the o-ring to harden as quickly (timewise).
    The three factors that should be considered are mileage, heat, and time. An o-ring that might last 50k over two years might be junk after only 20k after 10 years.
    The easiest way to tell if it needs replacing is to see how far it sticks up from the groove in the filter cover. If it's not pliable or it looks noticeably flattened, replace it. The biggest problem is that many people don't inspect them during a filter change, they just tighten it back up (until it leaks).
    Don't try to strengthen the saying that "the cheapest thing on a BMW is the rider". Be smart how you spend your money. $2-3 every few oil changes vs the possibility of a leak should be an easy choice.
    Mine, Hers, Spare
    Jun 2009
    Rochester, MN
    I agree. I change them every month.
    Fixed it
    1995 BMW K75s - 100k and climbing!
    2007 BMW R1200RT - 62k
    2009 BMW G650GS - 22k and ready for Alaska!
    RK Ryder
    London, Ontario
    I change mine with each oil change. Possibly too proactive but for a few dollars, I eliminate the headache of an oil leak.
    Paul
    Niagara Riders & Knights of the Roundel #333
    Don't know if they still do, but BMW used to sell an "oil change kit." It included the oil filter, along with washers for the tranny and rear drive fill and drain plugs, plus the oil cover o-ring.
    Forgot the price, but it was within a few bucks of the filter alone.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by JeffDiCarlo View Post
    They still sell the kit.
    $19.45 for the filter.
    $25.27 for the kit.
    Lee
    2016 R1200RS
    MOA # 30878
    Dec 2013
    Van Horne, Iowa
    Thanks everyone. Got the tune up kit yesterday.....Appreciate the input, I should have known better. The 08 LT now has 26K, so will do all the filters as well.
  1. Fuel pump/filter access hole a wee bit too small?
    By jconway607 in forum Oilheads
    Last Post: 08-30-2016, 01:46 AM
  2. Replies: 11
    Last Post: 11-01-2012, 07:38 PM
  3. Replies: 5
    Last Post: 05-09-2011, 01:22 AM
  4. fuel filter plate o-ring
    By phoenixtexas in forum Oilheads
    Last Post: 03-26-2005, 01:54 AM
