Results 1 to 7 of 7
Thread: wethead clutch
    wethead clutch
    Please be patient with me as this is the first time i"ve started a thread.Does anyone know roughly how many miles a wethead clutch with alot of highway miles and very little if any abuse might last.Besides a slipping clutch are there any symptoms indicating a clutch is getting near the end of it"s life? And has anyone had to replace theirs yet?
    Registered User crustybeemer's Avatar
    Oct 2015
    Pembroke Ontario Canada
    The wethead clutch is now a wet multiplate and like other wet multiplate clutches should last for a very long time- certainly much longer than the previous dry single plate clutches! 50,000 km on my '16 and no problems!
    2006 DL 650 V-Strom
    2016 R1200RT
    Addicted to windshields Realshelby's Avatar
    Aug 2015
    Houston, Texas
    I have not heard of any clutch issues with these Wethead Boxers. Including the GS version, which should get more clutch abuse than the RT version would. Not a thing to worry about at all. Fairly uncommon to wear out multi-plate wet clutches unless there is EXTREME abuse. I have a customer that sent his clutch components in with 304,000 miles ( 2003 DL 1000 Suzuki that has 426,000 miles on it now) on them and the clutch plates still measured well within factory service manual specifications.
    May 2017
    Guadalajara, México
    Not to hijack the thread, but the dry clutch on my 1970 R60/5 lasted 200,000 miles. They were mostly freeway commute miles.
    Will
    MOA #2607 - 2015 R1200R Cordoba Blue
    Previous: 1999 R1100RT Tundra Green • 1987 R100RT Grey • 1970 R60/5 Black • 196? Honda 305 Super Hawk • 195? Sears Allstate 50 cc Moped
    Barback King rapiddog's Avatar
    Jan 2004
    Acton, SoCal just West of Hell
    ...if I remember right there were some issues with earlier GSW clutches going south and needing replacement under warranty.
    Being new to the "W", I'm hoping it's gonna last a long time.
    I do have the quick shifter. I'm learning to only use it only from gears 3-6 on acceleration with full throttle on the upshift.
    Downshift full off-throttle gears 6-3.
    It doesn't seem to really like anything else, too much driveline and torque strain, but otherwise works smoothly in that range.
    Dooes this have much to do with clutch life? I dunno...
    "...the burble of my exhaust unwound like a long cord behind me. Soon my speed snapped it, and I heard only the cry of the wind...." Larry of Arubia
    Quote Originally Posted by rapiddog View Post
    I do have the quick shifter. I'm learning to only use it only from gears 3-6 on acceleration with full throttle on the upshift. Downshift full off-throttle gears 6-3. Dooes this have much to do with clutch life? I dunno...
    All else being equal it could slightly extend your clutch life since half the time you're managing to get a gear shifted w/o having to manually re-sync (rev-match). I don't have quick shift but like you shift w/o the clutch in 3-6th gear, but only going up now downshifting.
    You might want to look at my post on "slipper clutch and friction zone." The 13-16 clutches do have an issue that BMW is well aware of but they made changes on the 2017 to remedy it.
    Old But Not Dead
    Semper Fi
  1. Replies: 21
    Last Post: 10-08-2016, 01:44 PM
  2. Wethead and Twinmax?
    By 36654 in forum Wetheads
    Last Post: 08-11-2016, 02:00 AM
  3. Anyone buy a non-ESA Wethead?
    Last Post: 06-12-2015, 09:18 PM
  4. Do you like the wethead clutch?
    By irish in forum Wetheads
    Last Post: 05-23-2015, 02:58 PM
  5. I have the Wethead Bug
    By Rich in forum Wetheads
    Last Post: 10-17-2014, 10:19 PM
