Results 1 to 14 of 14
Thread: cleaning the wheels
    Registered User slatefish's Avatar
    Nov 2014
    bolton,ma
    cleaning the wheels
    well after a summer riding and not cleaning wheels on bonnie (aka 2000k1200lt) the gathering of clams ,dirt road in , stripe bass gunk from transporting fish to kitchen in a too small cooler and other organic and non organic wheel fouling elements ,heres the list of tried cleaners in no particular order windex, brake cleaner , wd 40, paint thinner and last but not least gasoline, they are cleaner than they were but what im looking for is nuclear cleaning solution . Did I mention i'm somewhat arthritic and though i don't mind cleaning the rest of her and keeping all the leather happy I somehow cringe at the wheels as they have all sorts of nooks and crannies that defy my efforts to clean. Now you may think I'm a whiney, lazy good for nothing, not worthy of such a fine instrument of happiness kind of guy , but all I really want to know is what you use, oh gods of beemer riders pleas take pity on my worthless soul and enlighten me . thanks a lot scott!
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    I use Simple Green, but I don't let my wheels get as bad as it sounds like you do.
    There are many specific wheel cleaning chemicals available at any car parts stores, any of which should work better than the chemicals you used. Just make sure you use stuff made for painted wheel so as not to mess up the powder coat.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Minnesota
    S100 wheel cleaner works well for me.
    RK Ryder
    London, Ontario
    Simple green and a IKEA toilet bowl brush. If really bad, some degreasing chemical. The right brush makes the job easier.
    Paul
    Niagara Riders & Knights of the Roundel #333
    2018 Volunteer Committee Chair 2018volunteers@bmwmoa.org
    Jan 2016
    Central Illinois
    Cleaning wheels
    They are just going to get dirty again
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Once a year or so, while I have a bike up on the lift, I use WD40 on a rag to clean the wheels. After that I use a mild degreaser. This works particularly well on bikes with chains.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Enjoy The Ride saddleman's Avatar
    Apr 2009
    Huntersville N.C.
    I detail my wheels at least twice a year. I remove the rotors when I clean them. I wash them with S100 then with WD-40 or Mineral spirits. I then use a fine cut buffing compound on the entire wheel with a microfiber cloth. Then they get several coats of wax. This wheel is over 17 years old with over 130,000 miles on it.Clean Wheel 004.jpg
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
    Registered User mlytle's Avatar
    Oct 2015
    alexandria, va
    Quote Originally Posted by Paul_F View Post
    simple green or purple power, a good brush and lots of elbow grease. even with that, if you let it go too long, there is a chance you will never get them really clean again.
    regular light cleaning saves work and damage in the long run....
    Marshall
    92 K75s
    94 K75s
    09 K1300s
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    Are you guys using Simple Green All Wheel and Tire, or just Simple Green? They make a boat load of products. And some not so friendly to aluminum.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    I just use regular full strength Simple Green on a paper towel to wipe down the wheels on my K75Ss.
    When the wheels are off, like when changing tires, I'll do a more thurough cleaning with a brush to get into all the crannies.
    Mine, Hers, Spare
    I use Awsome, a come in 26oz or 1/2 gallon. Diluted to 50/50 with H2O and placed in a spray bottle -elbow power with a stiff bristle brush
    Nov 2009
    Phila
    Cleaning OOPS
    I touched mine with paint thinner and didn' t wipe off soon enough so I have some clean wheels but the paint has some thinner and thicker streaks. I was going after rear end oil stain of thousands of miles. Often I spray paint my rims and spokes between taking off my old tire and putting on a new one, just Krylon, while spinning the wheel on a broomhandle across the top of a garbage can.
    Old 177 lb. wrestler from the 70s. Phila PA
    Kein Nasebohrer RBEmerson's Avatar
    Apr 2007
    SE PA
    Simple Green, what looks like a large bottle brush (from your FLAPS), and elbow grease. And not deferring the job to once a year, needed or not.
    If holding a brush is a challenge, time to strike a deal with someone possessed of strong hands and a weak mind...
    Some people are wise. Some people are otherwise.
    You should know that most commercial wheel cleaners use a deluded form of acid to lift off the baked-on brake dust that turns car wheels black. Problem is it also eats into the painted surface of the alloy wheels, leaving them etched and more inclined to hold on to the next round of dirt/brake crud. I never use wheels cleaners for that reason alone.
    Clean them anyway that works for you. I like the WD-40 approach, but you may have gone too long for that to work for you. If you really can't get the crud off, next time you have the wheels off for new tires, give them to a detailer and pay him to clean them for you. Then the important step: wax them. With a good coat of car paste wax, the next round of crud won't stick as well, though you should wash them more often than once a year.
    Mine wipe clean with a rag when I'm washing the bike. I re-wax them every time new tires go on.
  1. Trade Spoke Wheels for Cast Wheels
    By chewbacca in forum Wetheads
    Last Post: 08-01-2017, 04:38 PM
  2. Mag Wheels vs. Spoke Wheels
    By Bradkap in forum Motorrad
    Last Post: 01-04-2015, 11:20 PM
  3. Replies: 9
    Last Post: 04-29-2014, 06:08 PM
  4. Cleaning Wheels & Spokes
    By bluehole in forum Airheads
    Last Post: 11-03-2011, 01:27 PM
  5. Replacing snowflake wheels to spoked wheels...
    By lucky23 in forum Airheads
    Last Post: 08-02-2009, 05:05 PM
