Results 1 to 15 of 18
Thread: New 1600GT - What did you add?
    Registered User wkuwiz's Avatar
    May 2014
    NW arkansas
    Hello.
    Just picked up a new 2016 K1600GT last weekend. Found a white model at a dealer not too far away and the price was right. Felt a little guilt that I didn't buy locally but it's done. And it matches my wife's White R1200RT.
    Considering a few additions but thought I'd ask the board about what others have done first. Got to get a Shad Top Case. But other items?
    Stebel Horn?
    Illum Works protection?
    More lights? Hyper Lights?
    Let me hear from you.
    CW
    CW
    '06 F650GS Dakar, 2016 K1600GT
    See you on down the road!
    Quote Originally Posted by wkuwiz View Post
    Hello.
    Stebel Horn?
    CW
    Waterproof USB outlet - easily added on the right panel above the 12v socket. Maybe also a PDM60 or similar so you can power a tyre pump, since CANBUS trips out the standard 12v outlets at pointlessly low currents. That will also be a good first move if you’re planning any other electric gizmos such as horns and lights.
    Shame you won’t be able to fit a better radiator that doesn’t clog up!
    Registered User c4golf's Avatar
    Jan 2014
    Phoenix,AZ
    PDM for sure.
    Horn, definitely
    Clearwater or similar front lights. Stock is not enough for visibility
    Hyper, Skene flashing etc for rear.
    Better seat will most likely be obvious soon as well.
    Tim C
    2016 K1600GTL
    Matte Ocean Blue
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    You're off to a good start.
    The first thing I did was getting a Sargent seat...the OEM just doesn't cut it for me.
    Regarding your other items:
    Stebel Horn...yes. But its a pain to install.
    Illium Works protection...There are others out there that offer better protection. I have Wunderlich.
    Also, IMHO, getting the fronts without the rear is a waste of money. In a tip-over, the rear bag will crush. Cheap insurance.
    More lights...some have found adding lights beneficial. I do very little night riding so not a big deal for me. But if you add lights; consider the Clearwater (or equiv) mounted at the mirrors.
    Hyper Lights...I installed the Vizi-tech unit.
    RKA just introduced a very nice rear bag.
    Other things I added were:
    RCU Shelf...very handy.
    Pigtail for winter charging/electric vest/tire pump....etc.
    RKA inner bags...great for organizing.
    Enlarged brake lever foot pad.
    Footpeg lowering kit. I got long legs
    OEM Tankbag.
    Cee Baily windscreen.
    K&N Air filter.
    Have fun!
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    May 2014
    NW arkansas
    Quote Originally Posted by piglet View Post
    What's a PDM60? Is it like a "can opener"?
    CW
    Power Distribution Module - see pdm60.com for details. Probably easiest understood by looking under Installation for the quick start guide.
    Mar 2011
    socal
    Short antenna, dump the dorky 1600 and RT antenna
    Illum bars
    Skene P3 lights
    Kit to make front blinkers running lights
    RL Lemke drain plug
    Additional power let outlet direct wired to battery for heated gear/charging
    Kathy’s bags for both bikes
    May 2014
    NW arkansas
    Added Items so far
    Okay. Got the bike and added:
    1). Denali Sound Bomb
    2). Wunderlich Front and Rear bars
    3). Shad Top Case
    4). Nav VI
    5). Hyperlights for rear.
    6). Installing 3M film protection as soon as it gets here...
    Under consideration - Hex EZCAN and ADM Monster 44's on the bars, RKA 13L Tank Bag with pigtail installed. Any other bright ideas? Cold winter!
    Love to see and learn from all you people.
    CW
    Are we becoming just like Harley riders, adding accessories?
    May 2014
    NW arkansas
    Yes - to stand out....
    Yes - we are like many amongst the Western Civilization looking to make ourselves unique amongst the masses.
    It's a failing quest to be unique but added horn volume and more, brighter lights are a choice I like.
    Cheers Paul. I still don't have a doo-rag nor do I call my wife old lady; oh, she's not a pillion either. She's a rider like Voni!
    CW
    May 2014
    NW arkansas
    3). Shad Top Case
    4). Nav VI
    Update! Started on the 3M Film - been too cold for anything not brought inside.
    Added the HexEZCan (so wonderfully simple and programmed for conspicuity) and a pair of ADVMonster Model 30 spots. I'll take photos at dusk and post them in the lighting forum to demonstrate. Also love the RKA Tank bag. Hard-wired a dual USB up into the bag for rainproof charging on the go or when stopped for lunch.
    Had my first bout of A fib which has set me back for a couple months but am eager to ride again.
    Cheers!
    CW
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Clearwater lights and CANopener
    Sidestand foot enlarger.
    Beyond that, just a larger windshield for when my wife is riding pillion. Oh, and a top box for the same reason.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
    Hello.
    Stebel Horn?
    CW
    Windshield from 7jurock,Sargent seat,Alt engine guards w road pegs....Most important is EXTENDED warranty because the 6 cyl engine has a piston cracking problem and has had this problem since 2012 ...BMW as usual has ignored this problem just like most major problems they have had in the past... its so bad they can't provide replacement pistons for the repair...My 2013 is in the shop at Orlando and has been there for two weeks and there are no parts anywhere to fix it....BMW has been no help according to the service Mgr. on this problem and they have had 4-5 of these ...so I have spent most of my savings to buy a turd...No loaner,no bike to ride,no parts to fix it....Bashing BMW you bet I am....sorry but I'm telling you guys to prepare for this problem!!!!!
    Dave Norton
    Feb 2018
    Sedona, AZ
    Added Items
    Greetings all! I'm new on here but have had BMW's for 22+ years. I just picked up a 2018 K1600 GTL Ebony on Thursday. LOVE the ride compared to my 2003 LT, but . . . . WHY did BMW make the darn cases smaller! I'm also puzzled why they sell a bike in the USA with a GERMAN USB port that we have to buy an adapter for . . . And the phone compartment doesn't hold my Android phone at all! It will be in my jacket pocket or in the top case on a charger as soon as I add the outlet.
    I've added a MoDoor garage door opener after reading about them on here - pic attached. On the MoDoor, it is fastened to the black plastic box near the battery area and I put a piece of black Gorilla tape over the logo so it blends in with the bike. The buttons are very easy to reach and inconspicuous.
    I also installed the Brake Buddy air compressor that I had under the top case on my LT. it is VERY neatly mounted and the hose is readily accessible. All I have to do is open the seat and hit the switch, which I may mount permanently some say when I am in the mood to cut plastic . . .
    I added HyperWhites on the shelf under the headlight and they work wonderfully! I have the high brake light but want to get a modulator on it soon so I'm still reading on those. I also added outlets for Gerbings plugged in directly for rider and pillion and of course, the dealer puts pigtails on all of their sold bikes. Gee, just had to buy a new charger because the pigtail has SAE connector and my existing good charger just had clamps. Oh well. I've got the Ilium bars and footpegs. Would love some pics of back bars on a GTL is someone has any.
    I have the extended warranty and still need to look for a good seat with backrest. Suggestions? I've heard that Sargent makes a good seat but they are known to be quite firm. The choices will be between Sargent, RDL or Bill Mayer - Rick did my last seat.
    I'll be on here reading as well as our riding!!!
    Dave Norton
    Mar 2014
    Apple Valley, MN
    Welcome to the forum and K1600 ownership.
    Lots of good info here as well as the K1600forum.com
    Joe
  1. Thinking about a new 1600GT - Do they still have issues?
    By bigwaves in forum Straight 6 K1600 GT/GTL/B
    Last Post: 02-28-2018, 10:53 PM
  2. Bar Backs for the 1600GT
    By dirtyjimmy in forum Straight 6 K1600 GT/GTL/B
    Last Post: 09-12-2012, 03:15 AM
  3. 2012 1600gt
    By bullet in forum Straight 6 K1600 GT/GTL/B
    Last Post: 06-28-2012, 11:31 PM
  4. 2 up - 1200rt or 1600gt - what is best choice?
    By brprider679 in forum Motorrad
    Last Post: 12-03-2011, 09:41 PM
