Results 1 to 11 of 11
Thread: Need help with windshield bracket on 04 1150RS
    St. Louis, MO
    Anybody have experience changing the windshield bracket like this? (I think I discovered the limit with a tall C Bailey screen and 20MPH headwind @80 LOL)
    I think I have to pull off the 2 side panels next to the instrument cluster. Here is the right side
    I took out the screws, but the plastic panel piece doesn't seem to come out without a lot of force pulling away the silver fairing lip on the right. The instrument cluster doesn't allow me to pull to the left. Is there an easier way, or is there a direction to pull it that works the best? I am afraid of cracking it if I pull to hard. Thanks for any suggestions.
    Liaison 20774's Avatar
    Check the threads in the Similar Threads pane at the bottom of the screen. I didn't see anything right off, but I probably don't fully understand the situation.
    St. Louis, MO
    Yes I did look through those threads. My bracket is definitely broke and I have obtained a new one. Since all fairings are different this is a RS question.
    Aug 2003
    Marion,Ar.
    I've got a '94 R1100RS. I've had that panel off several times. It's been a while, can't remember any real problems removing or installing it. You may need a small slim flatbladed screw driver and gently pry the panel out. Put some tape around the blade so as not to scrape the paint off the fairing. Slow and deliberate is the speed of removal and install. Don't force anything. Plastic breaks easily. Good luck with your project.
    Nibley, UT USA
    Yes, you need to pull the two inner fairing panels. Remove the screws then beginning with the black panel that overlaps the other, lift the panel slightly at the innermost screw—the one underneath the L or R signal indicator, visible in your photo—and pop the panel inward toward the center of the bike while with the other hand helping the panel pop inward and away from the fairing. Sounds tricky, but it’s not once you’ve done it a few times. With those panels out of the way you’ll have access to the windshield mechanism. A bit of a pain to get at, but gee-I really miss my R1100RSL.
    Best,
    DG
    DGerber
    1983 R80ST -- 1988 R100GS "Bee"-- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Jan 2016
    Central Illinois
    Top panels
    Just went out to garage to refresh memory, two Allen head bolts on each side front top, 1 bolt each side very back by tank and one right in middle in front of speedometer cluster this one goes through each faring piece they kind of snap together ( fit togeather ) so you need to see which one is on top and remove that side first
    So 7 bolts on 94 1100RS do not think you have to remove two side faring panels but you might they do come off easily on my bike allows you to check other stuff
    Thinking more on this I had mine off when I changed the speedometer so you also have to unscrew the adjustment knob bolt thing and remove so you can pull spedo cluster up don't remember if you unscrew knob with it locked down or when popped out do remember it was harder to reinstall than to remove.
    Also if you want different bulb in headlight now is good time
    Gt rider typed faster than me so do what he says if you still can't get them out look at speedometer cluster and pull it up
    Last edited by 179212; 10-30-2017 at 06:19 PM. Reason: Smarter person answered first
    Jan 2016
    Central Illinois
    1100rs
    Quote Originally Posted by GTRider View Post
    Best,
    DG
    If you really really miss your 94RS your welcome to work on mine anytime
    Nibley, UT USA
    Quote Originally Posted by 179212 View Post
    If I lived closer I’d be happy to help you with that. Great motorcycles, and much easier to work on than the K-bikes!
    Best
    DG
    DGerber
    Registered User Blacque Jacque Shellacque's Avatar
    Nov 2005
    Pickering, Ontario
    GT rider is correct. Grab the panel near the tank, and pull it inwards. (BTW there is a small screw there holding it to the side panel) The panel has a lip which locks it under the side panel.
    You also need to remove the speedo/tach, and loosen the headlight assembly. If I recall correctly, the bracket is wedged between the fairing frame and the headlight assy. That is why the headlamp must be loosened. It's easier to do with the front fairing removed, but it's not necessary. There are 4 screws that hold the headlamp. Do not over tighten on reassembly. The fasteners can be easily pulled out of the panels.
    St. Louis, MO
    Quote Originally Posted by barryg View Post
    Good idea on the tape, thanks.
    Registered User jagarra's Avatar
    Aug 2016
    Reno, NV
    Those panels seem to hang up right on the bottom corner where they meet the side and front section. I remove the side panels and remove that screw on the top corner that ties the front section to the tank, now one can pull the corner of the front section out a little so the instrument cover can be removed.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Concours
  1. Replies: 9
    Last Post: 05-23-2016, 05:42 PM
  2. 2004 r1150rtp broken windshield bracket
    By Bcmcmoose in forum Oilheads
    Last Post: 10-25-2015, 11:35 PM
  3. Lower Windshield Bracket Snapped! '05 R1200RT
    By greenwald in forum Hexheads/Camheads
    Last Post: 06-22-2012, 05:21 PM
  4. Windshield Bracket
    By drcabe in forum Hexheads/Camheads
    Last Post: 09-24-2009, 01:26 AM
  5. 97 R1100RT Windshield bracket bent
    By cwidmer in forum Oilheads
    Last Post: 10-10-2008, 10:44 PM
