Results 16 to 18 of 18
Thread: Intermittent Ignition Fault
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Rob,
    Had you previously parked in that spot without incident?
    David Brick
    Santa Cruz CA
    2007 R1200R
    Bad ignition switch
    My 2009gsa acted just like your bike then the bike started to shut off going down the highway. The problem was the ignition switch two small screws replaced in 5 minutes.
    Registered User oldjoebmwrider's Avatar
    Jul 2009
    Corinth, MS
    Intemittent Ignition Fault
    https://forums.bmwmoa.org/showthread...nition-switch-!
    I pulled the ignition switch and sprayed all connections with electronic cleaner and all was well, never happened again. Good luck!
  1. 02 R1150R intermittent rear ABS fault
    By slowrider60 in forum Oilheads
    Last Post: 09-08-2017, 04:52 PM
  2. 2009 r1200gs, intermittent ignition switch !
    By oldjoebmwrider in forum Hexheads/Camheads
    Last Post: 01-14-2016, 03:31 AM
  3. r1100r ignition switch fault
    By hmdalton in forum Oilheads
    Last Post: 06-25-2012, 10:25 AM
  4. Intermittent Electrical Fault
    By dbrick in forum Oilheads
    Last Post: 05-28-2010, 02:47 PM
