Results 1 to 15 of 18
Thread: Cylinder Head Identification
    Aug 2010
    Calgary, AB. Canada
    Good afternoon to everyone,
    Several week's ago I bought a collection of parts for Airheads and Norton Commando parts. There was more Norton parts than Airhead but in the |pile I came up with a dirty pair of double plugged BMW Airhead Cylinder Heads. They were dirty as H*#l and took them and got them Vapor Cleaned at a local shop here in Calgary. The difference is amazing, but I have no idea what these heads will fit, thus I am asking if anyone has any idea what I have?
    On the inside where the valves are it is stamped 30/22.
    Rick MacPherson
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    Liaison 20774's Avatar
    Well, they're obviously dual plugged. I see the date stamp of '77, so my guess is they're likely 1977 R100/7 heads. Here's a link to the heads on my '78 R100/7 after refurbishing:
    https://forums.bmwmoa.org/showthread...l=1#post854525
    The mold number on my heads appears to be a higher number than yours, so that's why I think they're for 1977. I'm not sure I'd know if they were R75/7 heads, though.
    Jul 2017
    Bunbury WA Australia
    I've got a set of spare heads that came from a 78 R100/7.
    Hope it helps.
    Steve
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Serial number?
    Is that the serial number on the heads? The microfiche for BMW parts should be of help. St.
    No serial number or part number on the heads. As a general rule, BMW never puts part numbers on parts. The number you do see in the figures is a mold number for which there is no information about.
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by STEVENRANKIN View Post
    Thank you for the comment, but Kurt is right about BMW not putting parts numbers on castings. What you do see is a foundry forging number.
    In comparing my heads on the other heads under my comment, it stricks me that the two heads are a matched pair.
    If you look at the L10 - R10 (left and right side)
    1 263 947 (L10((left side)) and 1 263 947 (R10((right side))?
    SiCu is a foundry metallurgical # of what the head material is?
    Si - Silicon, and Cu - Copper which is mixed in with the aluminum for heat treating to stress relieve?
    Rick MacPherson
    The L10 and R10 probably indicates they are 1000cc heads. The SiCu does represent something about the aluminum alloy. I found an old post by Oak where he said the silicon was approximately 8% and the copper was approximately 3.5%. Oak was a metallurgist.
    Nov 2009
    Ontario, Canada
    does it make any sense to measure the intake and exhaust ports? didn't the the early R100 have 40 mm I, 40mm Exh. just wondering if that could get you one step closer.
    Louie..._/)....
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by louieskretas View Post
    Your comment makes sense, as the chap whose parts I bought from also had a 1979 R100RT with I believe 40mm Bing carbs on the machine . Will go look see!
    Rick MacPherson
    Nov 2005
    Calgary, Alberta
    Rick:
    Dave Anderson (Anderwerks) can figure out what they are, for you.
    Rinty
    Measure the ID of the exhaust ports and the diameter of the ground/angled portion of the valve seats.
    Anton Largiader 72724
    Tech articles
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Aug 2010
    Calgary, AB. Canada
    Good morning Anton! BeforeI went to bed last night, took a micrometer out into the shop and measure the exhaust ports and they are .040 mm. So that answers a few issues.
    The 1979 BMW R100RT that was purchased along with the parts has .040mm Bing carbs on the machine.
    Rick MacPherson
    40mm (.040 is a very different number) exhaust ports pretty much narrows it down to a '77-era big-valve R100 head. I have a '79 R100RT in parts and I have those same heads. 44mm intake and 40mm exhaust valves.
    Tech articles
    Maybe Rick meant 0.04 meters!! I just measured the valves that came out of my '78 R100/7. The intakes are 42mm while the exhaust are 40mm.
    ... which FWIW is normal for a small-port (32mm carb, 38mm exhaust) R100 head.
    Tech articles
  1. Cylinder head identification
    By LCampbell in forum Airheads
    Last Post: 01-13-2015, 10:56 PM
  2. Replies: 17
    Last Post: 05-30-2012, 09:14 PM
  3. Cylinder head leaking
    By helipilot04 in forum Airheads
    Last Post: 04-27-2009, 08:49 PM
  4. R65? Master Cylinder part identification help needed
    By KHEEREMA129911 in forum Airheads
    Last Post: 11-26-2008, 03:41 PM
  5. Cylinder head protectors.
    By lbrackr756 in forum Airheads
    Last Post: 11-09-2007, 11:03 PM
