Results 1 to 9 of 9
Thread: new rotor 5.5 ohms
    Registered User beano08's Avatar
    Oct 2017
    Hartford CT
    new rotor 5.5 ohms
    Hi all,
    Any reason why a new rotor from Rick would come in at around 5.5 ohms? It's for a /6 so I was expecting closer to 3. Do the rings need to be lightly sanded and cleaned? There's definitely a film of oil covering everything
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Rotor
    Have you asked Rick? He will give you an honest answer. You trusted him enough to purchase the part from him. His reputation for customer is excellent. BTW, I am assuming you mean Rick Jones.
    Friedle
    Ride fast safely
    Liaison 20774's Avatar
    5.5 ohms is no man's land...should be 3.4 or so. The earlier rotors were 6.9 and the later ones were 2.8. I would think that the meter probes should cut through the oil to make good contact.
    Registered User Guenther's Avatar
    Colorado Springs, CO
    When you measure such low Ohms test the tips by connecting the tips first. Some meters might already show some low resistance which you have to subtract from measuring the rotor.
    For the measurement it might help to lightly rub the tips on the copper rings of the rotor.
    My replacement rotor was cold 2.8 Ohms (3.3 according to specs) - yes, temperature also makes a difference when measuring a low resistance.
    And Rick might tell you that what you measured is about the resistance for your model according to specs.
    /Guenther
    Apr 2007
    Nacogdoches, TX
    Not trying to disparage your meter, but are you sure it's accurate and zeroed?
    At those small readings it doesn't take much to move an ohm or two.
    '08 BMW R1200RT
    Oct 2017
    Hartford CT
    Quote Originally Posted by Guenther View Post
    /Guenther
    I'm dumb, meter measures about 3.0 on its own which would put me spot on. Bike is charging at a healthy 14.2 volts at barely 3k rpm! Thanks all for your help!
    Apr 2007
    Nacogdoches, TX
    Cool beans, daddio!
    Or some such congratulatory exclamation.
    '08 BMW R1200RT
    DeLand Florida
    Quote Originally Posted by beano08 View Post
    Now, go ride and enjoy the bike. Glad it is up and running.
    Wayne.
    Vancouver, B.C. Canada
    Sign up for harbour freight coupons and get their cheap digital meter for 10 bucks or less. Some sales lately they give you one for free if you buy anything else!
    They will measure better than the one you are using now. I've checked one against my Fluke which is a decent unit and they are bang on.
  1. Possible warped rotor
    By BMARC153920 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 07-19-2017, 11:28 PM
  2. k75 fuel lights purpose and sender unit ohms?
    By jconway607 in forum Flying Brick K-bikes
    Last Post: 03-20-2015, 05:44 PM
  3. Rotor wear
    By gerzinam in forum Oilheads
    Last Post: 09-19-2010, 07:04 PM
  4. Brake Rotor
    By LCampbell in forum Airheads
    Last Post: 07-31-2007, 06:24 PM
  5. What does it fit ? NOS rotor marked 1 236 337
    By MitchNNPossible in forum Airheads
    Last Post: 06-23-2007, 01:33 PM
