Results 1 to 3 of 3
Thread: 2006 R1200RT Rear Seat Heater Wiring
    I have a brand-new-to-me '06 R1200RT with a rear seat heater connector that been pulled apart. I'd appreciate it of someone will compare theirs to mine to verify that the way I've aligned the wires is correct. Rear Seat Heat Connector.jpg
    Thanks for the assist.
    Zipper
    {Imagine something witty here}
    Bump
    Any takers to assist?
    Thanks, in advance
    Central Ohio
    I don't have heated seats, but this might help. Most BMW connectors have molded-in wire position numbers on both ends. Your plug should match the numbers shown here, 1-2-4-3. (strange way to count, no? )
    I usually need good light and my readers to see the small numbers.
    edit: Just realized the numbers are out of order to make the drawing easier to follow. If the bottom position on the white plug is number 1, you are good.
    Larry
    2006 R1200RT
  1. 2012 R1200RT seat heater ?
    By mifeinstein in forum Hexheads/Camheads
    Last Post: 10-01-2016, 04:07 PM
  2. Seat Heater OEM Plug for R1200RT
    By 43883 in forum Hexheads/Camheads
    Last Post: 03-31-2015, 07:31 PM
  3. 2009 R1200RT Heated Seat Wiring Plug?
    By tgf429 in forum Hexheads/Camheads
    Last Post: 01-29-2014, 03:39 PM
  4. 2010 R1200RT Seat heater won't turn off!
    By PARon in forum Hexheads/Camheads
    Last Post: 06-01-2013, 02:46 PM
  5. Pillion seat heater plug 2011 R1200RT
    By BlackDenis in forum Hexheads/Camheads
    Last Post: 04-23-2012, 05:11 PM
