Results 1 to 14 of 14
Thread: Winter Storage
    Registered User lasnin's Avatar
    Jul 2017
    Susanville, California
    Winter Storage
    Well, for me in my geographical location, I may only one more month of safe, comfortable riding left..
    So besides keeping the bike in the garage with cover, and some Stabil in the gas and using the battery tender now and then, are there any other suggestions for winter ❄️ bike storage?
    TIA
    Quote Originally Posted by lasnin View Post
    TIA
    Regarding a cover, inside a building I would use a permeable cover like a bed sheet instead of a water resistant bike cover. This will keep dust and any bird debris off the bike but won't trap moisture under the cover.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I recommend disconnecting the battery to eliminate any parasitic electrical draw. If your battery is healthy and stored fully charged in a cold environment, then you can turn on the tender once a month and it will be good.
    Do you have mice? They can do damage. Not something I've ever had trouble with but supposedly mothballs will keep them at bay.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    RK Ryder
    London, Ontario
    Have I been doing this wrong? After changing all the fluids, I have always left the battery tenders connected to both bikes all winter. The Odyssey in the K lasted seven years doing this.
    Mothballs and traps must work as I've never had a mouse problem. Of course there have been complaints from my better half about moth ball odour.
    Paul
    Niagara Riders & Knights of the Roundel #333
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    I've also left the battery connected all winter. I alternate the smart charger from bike to bike every two weeks, plugging it right in to an SAE connected directly to the battery. Any parasitic loss is corrected when it's plugged in. Other than that, I change all fluids before putting them up. The sidecar rig goes up on jackstands to make winter cleaning easier and to keep the tires from prolonged contact with the concrete. The two-wheeler goes on the centerstand with a wad of bubblewrap under the front tire.
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Glenlivet
    '15 Honda CRF250L for exploring places I'm afraid to take the big GSA!
    http://travelswithbarley.com/
    Jul 2007
    Quote Originally Posted by Paul_F View Post
    Not if what you are doing is working for you.
    Kevin Huddy
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    When I put the bike away for the winter, in addition to Stabil, I always fill it with non-ethanol fuel. You can find a station near you here:
    https://www.pure-gas.org
    Jul 2017
    Winter Storage follow - up
    Hey folks, thanks for all the suggestions, now I am just worried about parasites and mice!
    Seriously, what are opinions on actually starting the bike up every now and then and letting it idle for a few minutes?..
    TIA
    Jan 2009
    Craftsbury, Vermont
    TIA
    Bad idea. Terrible. Sad! Wrong in a bigly way!
    First, when you change the oil the virgin stuff is pure as can be.
    Secondly, idling the engine for just a few minutes won't bring it up to the temp where moisture is burned off. If you're going to start it, run it hard for an hour.
    TIA
    Not recommended.
    starting bike periodically
    TIA
    What you need to do is get it up to operational temperature for a significant time to allow enough time to evaporate any water that may have condensed in the crankcase. A brief run without a non-trivial period of being fully warm is probably not a good idea. Best option is just to ride for a 1/2 hour a month, if you are able (considering snow, etc.) Keeps the battery up, too.
    Jul 2007
    Lasnin, completing your profile and providing your location and model of bike will be helpful.
    Kevin Huddy
    Mansfield,MA
    Mice have already been plentiful around here- I like a mixture of "bait" and traps. The mice create problems with their urine, their chewing and nesting- especially in the air-boxes. If the bike sits for a time and you suspect mice, it's good to have a look in the air-box/filter area so you don't suck nesting materials into the engine intake.
    As for starting once in a while, I don't think it matters much. The bike sat for months before it was purchased. I'm a fan of a battery tender for obvious reasons. I like a bit of a cover (not tight plastic) to keep the dust and what-not off. If you can fill and run with non-ethanol gas, you will be amazed at the benefits especially with a dose of Techron, some Stabil and a bit of two-stroke oil. I like the two-stroke oil- or Mystery oil, for the coating it leaves inside the gas tank and other metal surfaces as an inhibitor to condensation induces flash rust.
    Good Luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2017
    Scooter Forum.
    I am in the far NorthEastern corner of California, having moved down here after 12 years in Sitka, Alaska.
  1. prep for winter storage
    By badgertom in forum Airheads
    Last Post: 10-14-2012, 07:49 PM
  2. Winter storage
    By SOREASS in forum Airheads
    Last Post: 10-08-2010, 02:20 AM
  3. Oil from Winter Storage
    By hintzir09 in forum Hexheads/Camheads
    Last Post: 03-13-2009, 06:25 PM
  4. Winter Storage my K75
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 10-22-2008, 01:53 AM
  5. Winter Storage
    By badgertom in forum Oilheads
    Last Post: 10-01-2008, 07:12 PM
