Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: 14 RT low beam bulb
  1. #16
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    Not to sure about other states, but in Mass. it is illegal to alter your head lights or tail lights. I waited in line at the Reg. of motor vehicles to ask about it and I was told by a very angry employee not to change anything or I could get a ticket or fail inspection. If pulled over the officer could have my vehicle towed. I apologized for wasting her time and left scratching my head.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
  2. #17
    Addicted to windshields Realshelby's Avatar
    Aug 2015
    Houston, Texas
    Quote Originally Posted by junkjohn View Post
    Yes.....and No......It is illegal to use unapproved headlight assemblies or bulb replacements. Mostly due to light pattern changes. There are replacement headlight assemblies that ARE DOT approved and 100% legal. Mainly for cars and trucks at this time, most are LED. Legal replacement headlight. If "alter" included using a replacement bulb that was a match in every way, but a different brand, you can see how that might be a problem. So, my take on the motor vehicle employee is that they don't know the correct way to answer your question.
  3. #18
    Aug 2010
    Collinsville IL
    led
    Quote Originally Posted by davagail View Post
    not sure how it works but dust cover is one and cyclops told me cover would fit with resistor installed too! time will tell
    resistor showed up and is plug and play! getting everything under dust cover is challenging but can be done!! seems to have solved the problem,haven't went for ride yet but in the garage for 15 minutes or so with high beam on no bulb failure on dash!!! fingers crossed
    2014 R1200RT
    Now gone 09 RT
    10xxx and going!
    living for riding,riding reason to live!
  4. #19
    Feb 2010
    Cape Cod, MA
    She seemed to be saying you could not just put a brighter bulb in the headlight and you could not have a blinking tail light. I tried finding more on line with no luck.
    John Simonds
  5. #20
    Apr 2017
    Cooperstown NY
    re: blinking taillight, I was told the same in NYS during an inspection. First time anyone mentioned it in several inspections. I told him I installed it after this inspection.
  1. LED low beam or high beam bulb - with capacitors
    By jsoque in forum Hexheads/Camheads
    Last Post: 11-28-2017, 11:53 PM
  2. F800ST--How to replace low beam bulb????
    By royce in forum F-Twins
    Last Post: 09-14-2016, 04:36 AM
  3. High-Beam and replacement bulb
    By Olsensan in forum Oilheads
    Last Post: 12-03-2012, 09:58 PM
  4. low beam bulb replacement
    By PDOGGER in forum Oilheads
    Last Post: 07-27-2012, 01:03 PM
  5. RT low beam bulb
    By motofranz in forum Oilheads
    Last Post: 08-06-2004, 08:09 PM
