Results 1 to 14 of 14
Thread: GPS mounting options for the K1200RS
    Registered User bubbadozer1's Avatar
    Jul 2017
    Wenatchee, WA
    What are some of the options for a GPS mount on the K1200RS bike. I have a Garmin Zumo 665LM that I want to mount, but not sure what base I should use.
    Thx
    Quote Originally Posted by bubbadozer1 View Post
    What are some of the options for a GPS mount on the K1200RS bike. I have a Garmin Zuni 665LM that I want to mount, but not sure what base I should use.
    Thx
    I have a Zumi 695 LM mounted on my 2003 K1200RS using a RAM Mount plate that goes over the clutch reservoir. Works perfect.
    Jul 2017
    Wenatchee, WA
    Quote Originally Posted by skeive View Post
    Any pics?
    Any pics?
    Not at the moment. If weather cooperates and I can ride the bike tomorrow I will try and get one for you.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    This is the mount I used on my K1200RS.
    https://www.rammount.com/part/RAM-B-346U
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2006
    Nibley, UT USA
    From google, there’s this:
    https://www.motorcycleparts-hornig.c...-Mounting.html
    and this:
    https://touratech-usa.com/Store/Tour...0RS-and-others
    or this:
    https://www.rammount.com/part/RAM-B-180U with the angled bolt-mount ball fastened to one of the lower handlebar-mount clamping bolts. You’d need a longer Allen-head screw and a hardware-store aluminum spacer about 1/2” OD and 1/2” long, that just fits over the 6mm Allen screw.
    Best,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S PD — 1993 R100GS — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT
    The one I use is the 345 U (http://a.co/9mYxRbs).
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    BMW make one specifically for that bike. I had one on my 99.
    It mounts at the triple tree. Very slick and homologous with the rest of the bike.I don't have any pics but you might have to do some digging online.
    I did find this: http://tinyurl.com/y9fyc6v5
    Here is the P#: 71607669701
    Have fun!
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by 61996 View Post
    Have fun!
    Actually, that number is just the mounting block itself. The complete mount kit is part number 71 60 7 683 660 and it is supposedly still available on the MaxBMW website for $106 and can be seen at http://www.maxbmwmotorcycles.com/fic...0&rnd=07242017. Mounts the GPS a bit low for my tastes, and I've had trouble before with the rod-type mounts not staying tight enough to keep the GPS from rotating. In any case, looks like it is still available!
    Best,
    DG
    DGerber
    Any pics?
    Weather and schedule finally aligned. Here are those pics:
    Was using the phone to take the photo, but it usually sits in the ram mount to the right.
    I'll second Skeive's approach. I also use the Ram mounts, on both clutch and brake reservoirs, for my farkles. I use a conventional Garmin GPS on the clutch side. It's at a good height, and readily accessible to my left hand. I use the right-side mount for my E Z Pass transponder, but may substitute my cell phone to enable use of the Waze app.
    Only issue I currently have is viewability (?) of the GPS on sunny days. The screen washes out in sunlight, and the tinted visor makes it worse. Anyone find a visor/shield that fits onto conventional GPSs to deflects the sunlight? Folding a piece of cardboard is not really my style.
    Jun 2009
    Rochester, MN
    Quote Originally Posted by JeffDiCarlo View Post
    I too tried the cut down binder, plastic sheet, etc. but finally got a https://www.glarestomper.com/ - works great and hasn't moved even at "spirited" speeds.
    1995 BMW K75s - 100k and climbing!
    2007 BMW R1200RT - 62k
    2009 BMW G650GS - 22k and ready for Alaska!
    Jul 2017
    Wenatchee, WA
    Thanks so much for the pics!! Much appreciated.
    Jul 2017
    Wenatchee, WA
    Try the Glare Stomper. I love mine.
    WWW.GLARESTOMPER.com
    Cheers
  1. R100RT - GPS and/or gadget mounting options?
    By basketcase in forum Airheads
    Last Post: 11-04-2016, 04:43 AM
  2. RAM mounting options for R100 GS - Looking For
    By GlobalRider in forum Airheads
    Last Post: 05-13-2014, 01:15 AM
  3. Looking for Zumo mounting options on a GS
    By roburnmc in forum Hexheads/Camheads
    Last Post: 02-27-2008, 03:21 PM
  4. ZUMO 550 Mounting Options
    By pschramm in forum Gear
    Last Post: 05-15-2007, 07:28 PM
  5. XM vs. Sirius and mounting options
    By DZIMBRIC in forum Gear
    Last Post: 05-24-2005, 08:10 PM
