Results 1 to 7 of 7
Thread: NAV 6 - Continuing Saga - Why Contacts Not Loading
    I could not get the contacts to load into my brand new $950 USD Nav 6. Just got off the phone with Garmin, seemed like the Garmin rep knew the product well - good guy.
    Garmin says the reason my contacts would not load on to my NAV 6 was that my contact list in my Samsung S-4 is too large at 900 contacts. Rep says the maximum you can load is around 200 contacts. Rep also says it could take up to 20-minutes to load 200 contacts via bluetooth and that once the bluetooth connection is stopped, the NAV 6 loses all the contacts and needs to reload contacts again from the start with your next ride....after the 20-minute load delay.
    This seems to be a little different reason for the contacts not loading than I have seen here to date. At least the Garmin Guy provided a plausible reason versus it just won't work.
    1) 200 contact limit,
    2) long load time due to bluetooth, up to 20-minutes,
    3) (This one blows me away) contacts lost to Nav 6 when bluetooth connection is terminated, then must load again from scratch the next time you want to use contact list.
    I don't see a workaround to this problem for me. Darn........
    I do not wish to seem argumentative, but it appears to me you are trying to make a GPS into something it isn't designed to do. Garmin seems to provide a small capability to do a lot of different things. But it is first and foremost a GPS that can't be an information Grand Central Station.
    It is my opinion that it is best to use a GPS as a GPS, and a phone as a phone. That saves me a lot of frustration. A lot of folks disagree with me in this regard.
    Hi PGlaves!
    Yes, we pretty much disagree. I figure the product should produce the promised utility/benefits for the money I paid. I expected to spend considerable time learning a complicated system.
    Quote Originally Posted by tincup View Post
    Hi PGlaves!
    You have much more patience than I do. Sincerely, I wish you good luck.
    Sep 2013
    Toronto, Canada
    Phone call?
    Have you had any luck in making a phone call with your Nav VI?
    While I appear to be able to dial out, but I couldnít hear or converse with my C3-SRC.
    I suspect some of the issues might have soemthing to do with the new Do-not-disturb while driving feature on iOS 11.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Hey, I got my NAV VI to give voice directions through my Sena 20S. A major technical accomplishment for me. I think I'll quit while I'm ahead, although I may turn it off.... it's a bit irritating.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Quote Originally Posted by kevinsclo View Post
    Yes, I can make phone calls. The "Call Home" icon works and I can dial out using the Nav 6. I can use the music player off the Nav 6, I installed a 64G card. Have not figured out the filing system yet for playlists, etc.
    I'm using a UClear HBC200HD communicator in the helmet which pairs right up and connects automatically.
  1. Connector contacts
    By TGEORGE143784 in forum Airheads
    Last Post: 10-04-2012, 01:41 PM
  2. Continuing R 50/2 saga
    By johncrute in forum Vintage
    Last Post: 04-04-2012, 04:46 PM
  3. Cleaning Electrical Contacts
    By mbellantone in forum Airheads
    Last Post: 01-25-2009, 02:43 PM
  4. Glasses / Contacts
    By dbrick in forum Gear
    Last Post: 09-19-2006, 02:03 AM
  5. Continuing lighting upgrade
    By bmwcliff in forum Gear
    Last Post: 01-10-2005, 01:00 AM
