Results 1 to 12 of 12
Thread: The Dreaded Front End Squeak!
    Having completed nearly 13k on my glorious 20`5 K16GT, i have now acquired what appears to be a common issue, in the incessant front suspension squeak. I noticed it on a return from New Mexico, when entering small, quiet towns, and coming off cruise control as speed reduces to around 40, the wind noise allows the sound to penetrate the helmet. Its terrible!
    So Google was employed to see if others had this same predicament, and of course i wasnt let down. https://www.youtube.com/watch?v=prs3wtrleZI
    I reported it to my local dealer nearly 3 weeks ago, and am still waiting to hear what they intend to do about it, i refuse to hear that one of the most technically sophisticated companies in the world request that i spray the suspension bushings with Super Lubricant.
    Not looking forward to this drawn out saga as my bike wakes the locals and sounds like a 1969 Buick (not that theirs anything wrong with that)
    Quote Originally Posted by ukexile View Post
    ... I refuse to hear that one of the most technically sophisticated companies in the world request that i spray the suspension bushings with Super Lubricant.
    That is your choice, so enjoy your squeak.
    In my experience, sometimes lube advice is all you’re going to get from BMW. When transmission input shaft splines on airheads were failing with depressing regularity, we were advised to remove the transmission on a regular basis (!) and lube the splines with expensive imported German Staburags grease. The splines still failed of course but I think we all felt better about it for at least trying. The problem was never corrected and airhead owners still have to lube the splines regularly.
    It is, after all, a consumer grade motorcycle, not the space shuttle, and it’s just a squeak.
    If the spray lube takes care of it the problem is solved.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    I have it as well.
    Seems to be temperature related...the hotter it gets the more it squeaks.
    Not a big issue for me here in MN.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Quote Originally Posted by 61996 View Post
    I have it as well.
    Joe
    On the early telelever Oilheads the lower front strut (shock) mount would squeak. BMW called for greasing the shank of the lower mounting bolt. It became a routine part of maintenance. I have never been surprised to learn that moving parts require lubrication. YMMV
    Aug 2003
    Marion,Ar.
    Squeak-Squeak
    Ye, my '94 RS had/has the squeak. An occasional dab of light grease at the Shack bolt mounts pretty much stops it. No Squeaks.
    Registered User d martin's Avatar
    Dec 2007
    "The Gas City" SE Alberta
    K16 squeak
    Numerous threads on the squeak at the K1600 Forum. Noticed it more in warmer weather prior to getting my dealer supplied replacement shock this spring that didn't squeak going or coming from SLC!
    Aug 2006
    Raleigh, NC
    Squeak Solution
    My 2013 developed the squeak, people's heads would turn as I rode through small towns, they must of been thinking: well we don't like that Harley roar but this BMW squeak, now that's really annoying. Not good for the marque, you'd think they would have found a solution by now. I let my dealer work on it, squeak back in three weeks. Solution: bought an RT, no squeak.
    Quote Originally Posted by MHRUTTER View Post
    So is the squeak from the strut (shock) itself or is it from a hinged part of the suspension? Or don't the dealers know?
    Some of these bikes are out if warranty, so it may not be practical to have a dealer look for a cause of the squeak.
    Here’s an animated gif of how the front suspension works:
    http://theneed4speed.com/Images/episode5_3_vis_l_01.gif
    Hopefully, it might help someone troubleshoot the cause and find a fix for the problem.
    Dec 2007
    There are numerous threads about lubricating the shock shaft and about replacing the shock bushing (silent block) or installing a new shock to eliminate the squeak. Here is a summary of the steps one rider had with his service dept.
    According to the service dept. here, the squeak is NOT recognized as a real issue. In adddition, they are usually instructed from the mothership to do two steps. One, take the bushings out of the shock, test the shock for a squeak. If the shock squeaks, replace the entire unit. If the shock doesn't squeak, replace the bushings only (even though the dealership admittedly says the shock is a non servicable item).
    I had this problem with my 2016 GT. The squeak always occurred after a ride when the bike was warm. The dealer was willing to replace the shock. Not being thrilled with the idea of major front end work on a nearly-new bike, I decided to experiment and see if I could locate the source of the noise. After riding one day this July, I carefully lubricated just the bottom of the coil spring where it comes in contact with the black cone-shaped metal stamping. I went right back out on the road, and the squeak was gone. It hasn't come back in the intervening months and about 2000 miles. Could be coincidence or plain luck, but it might be worth a try to anyone interested.
  1. OK...Who's got that hideoous front end squeak!!!
    By mrmrsnct in forum Straight 6 K1600 GT/GTL/B
    Last Post: 10-10-2017, 10:31 PM
  2. Front brake drag and squeak '77 R100S.
    By georgej in forum Airheads
    Last Post: 07-13-2015, 04:36 PM
  3. Out Damned Squeak
    By TonysR100 in forum Oilheads
    Last Post: 05-15-2012, 06:30 PM
  4. K75 front brake squeak/chirp
    By barooo in forum Flying Brick K-bikes
    Last Post: 08-23-2009, 01:22 PM
  5. engine squeak
    By lagermann in forum Airheads
    Last Post: 08-01-2007, 05:37 AM
