Results 16 to 21 of 21
Thread: Charging Question
    Airmarshal-IL James.A's Avatar
    Sep 2013
    central Illinois
    [QUOTE=ebeeby;1107548]That doesn't necessarily mean that I'm right. I still do not fully understand the theory behind these things.
    To quote the Grateful Dead; "answers a plenty in the bye and bye".
    1973 R75/5
    Liaison 20774's Avatar
    Quote Originally Posted by James.A View Post
    From St. Stephen, one of my favorites!
    Registered User Guenther's Avatar
    Colorado Springs, CO
    I think James theory is close. But if any of the BIG diodes (to B+ and from ground) would fail the output to the battery would be LOWER because the failed diode would not add its share of its alternator phase to the DC output at B+/battery.
    But there are three LITLE diodes (to D+) which independently from the big diodes should produce about the same voltage. Their output is connected to the voltage regulators input and also to one side of the GEN light. If one of these little diodes fail there would be a lower output voltage on D+. Hence the regulator 'thinks' we are below 14.0V and increases the current (DF) through the rotor. Now the big diodes (all working) generate an even higher voltage at the battery. This higher voltage on B+ is also present at the other end of the GEN light. Now we have a difference between the two sides of the GEN light and the GEN light comes on.
    And bottom line: The diode board has a fault.
    Btw. with a stock voltage regulator (like from Hellas) and a good voltmeter you normally don't get 14+ Volts at the battery. Typically 13.70-13.85 Volts because of a voltage loss in the wire and connectors to the battery.
    /Guenther
    Broken connection
    Took the cover off this morning and it turns out one of the 3 alternator wires had a broken connection on the stator. Resoldered this wire and the problem went away. Thanks to all for your help!
    Charlie P.
    1992 R100R
    Thanks for reporting back the problem and fix. A disconnected phase cable of the alternator - same symptom as a dead big diode on the diode board.
    /Guenther
    Sep 2013
    central Illinois
    Many thanks to Guenther for providing the rest of the story and the true technical explanation.
    1973 R75/5
  1. Charging question
    By kgadley01 in forum Airheads
    Last Post: 05-16-2013, 10:06 PM
  2. 1986 BMW R80 Charging question
    By bullfrog_28560 in forum Airheads
    Last Post: 08-03-2012, 03:16 PM
  3. Charging question
    By bombayduck in forum Airheads
    Last Post: 08-23-2009, 07:54 PM
  4. Another charging question
    By lbrackr756 in forum Airheads
    Last Post: 06-09-2008, 03:13 PM
  5. R60/5 charging question
    By APEXERIC in forum Airheads
    Last Post: 05-23-2006, 03:14 PM
