Results 1 to 6 of 6
Thread: FOBO Bluetooth Tyre Pressure sensors
    Hi Fellow BMW Hex and Cam heads,
    I have just been reviewing the FOBO Tyre Pressure sensors for bike riders. Have any of you got these on-board and what do you think?? Are they the value that youtube is telling me??
    My research is telling me to get the T Valves as well. Do these combinations (T Valve and FOBO caps) clear all the brake assembly. And to cover all bases any wheel imbalance experienced??
    I look forward to your experience!
    Kind regards
    Aussie Bob
    Liaison 20774's Avatar
    Awesome Bob -
    This is the only thread I could find which mentions the FOBO product:
    https://forums.bmwmoa.org/showthread...ecommendations
    May 2016
    Northfield, Ohio
    I have the mobletron system that is talked about in the above thread and I like it a lot. The display is easy to read and the sensors are inside the tire so they give you temperature and pressure. I would recommend the Mobletron system.
    Just my 2 cents
    Roger L
    Registered User natrab's Avatar
    Sep 2012
    Antioch, CA
    I've used the FOBO system on my RT for about 20k miles and love it. I love how it stays in touch with the app as long as you leave bluetooth on (I'll sometimes get a ding on my phone in the bedroom when the tire pressure reads low at night from the cold temps). They seem pretty accurate and most importantly they let you know your tires have pressure without manually checking them or having to ride for a while before they give you a readout (like most TPMS).
    I'm not sure about the T-Valves. The RT has a sideways metal valve in the front and I put an angled metal valve in the back and the FOBO has plenty of clearance.
    Current rides:
    2013 R1200RT 90th - "Tyr" - 85k miles
    2012 R1200GS Rallye - "Carl" - 2500 miles
    Previous BMWs: 2011 R1200RT-P, 2007 R1200S, 2006 R1200RT
    Quote Originally Posted by natrab View Post
    Any chance you can put pictures up of your fobos?
    Registered User platypus's Avatar
    Dec 2017
    Boston
    FOBO won't clear the brake caliper on a S1000XR
    These look like a great product. Fit the back tire no problem, but won't clear the brakes on the front. Only solution I can see would be to drill a new hole into the rim along the center line and install a second (metal) valve stem. That would probably require a bit of careful machining of the center ridge to allow the valve stem to seal well.
  1. Tire Pressures (and pressure sensors)
    By bobs_one in forum Wetheads
    Last Post: 07-13-2015, 12:17 PM
  2. Tire pressure sensors......
    By middleagecrazy in forum F-Twins
    Last Post: 05-15-2013, 02:29 PM
  3. 2010RT Air Pressure Sensors
    By 105258 in forum Hexheads/Camheads
    Last Post: 10-15-2012, 03:24 PM
  4. Pressure sensors
    By hankhoward in forum Wedge K-bikes
    Last Post: 04-30-2011, 12:51 AM
  5. Tire (Tyre) Pressure Levels
    By 99007 in forum Oilheads
    Last Post: 08-27-2004, 02:46 AM
