Results 1 to 9 of 9
Thread: 03 k1200rs final drive oil change pictures
    Registered User bubbadozer1's Avatar
    Jul 2017
    Wenatchee, WA
    Just drained my final drive oil to examine after buying and researching service history. Service notes stayed might need to replace final drive crown bearing, but nothing more. So, these are the pics of the oil I just drained out. Because I'm new to this bike and BMW's, are these particles indicating a failing/worn final drive? I'm thinking the very small flakes in the pan say probably, but with my lack of experience, do t know. What are your thoughts after looking at pictures?
    Jan 2008
    So Cal
    Replace the bearing! You don't want the bearing failing on the road.
    Enjoy The Ride saddleman's Avatar
    Apr 2009
    Huntersville N.C.
    I have rebuilt over 100 of these final drives & that one needs to be rebuilt.
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
    Apr 2006
    Nibley, UT USA
    If those are metallic flakes in the oil, you should have that drive rebuilt while you might still get by with bearings and seals replaced and a proper re-shimming. Pressing the point by continuing to ride it might cause damage to ring and pinion.
    Iíve had two of these for my sidecar rig rebuilt by Tom Cutter at Rubber Chicken Racing Garage in PAóthe OEM and a used spare. The rebuilt OEM unit is still going strong in the SC rig after 25k+ miles so havenít needed the spare.
    Best,
    DG
    DGerber
    1983 R80ST -- 1988 R100GS "Bee"-- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Hard to tell from the pics if there really is an issue but, you got the $$ and the time and want to be safe.............................
    In the HD trade exam, there is a question regarding the exact same as posted in the pics. The correct answer is if there is no complaint, drain the oil and refill and check again at next service interval.
    1997 R1100RT (Restored Basket Case) , 1981 KZ 440 LTD (Restored Basket Case, my baby, fast, fun)
    3xR90/6, two just sold, one for a sidecar. 1983 K100RS (Cafe now)
    Very Rough R80RT. 1987 K1100RS (freaking hooped I think)
    Jul 2017
    Wenatchee, WA
    Final drive
    Since I have the FD I picked up on Ebay, it seems like that would be the easiest for right now, then maybe have the original rebuilt at my convenience?
    Thoughts..
    Astatula, FL
    Quote Originally Posted by bubbadozer1 View Post
    Thoughts..
    No guarantee the ebay unit is any better.......
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
    My understanding of the rear drive failure mode is that the bearing cage breaks, allowing the balls to sink down in the vertical races. With the balls all gathered at the bottom, the rear hub and wheels are no longer properly supported and positioned. Their movement exceeds the seals' abilities, so the first sign (if you don't notice the free play in the wheel) is that the fluid gets past the seals, onto the flange of the rear wheel. Eventually the whole wheel/hub assembly flops over from vertical.
    Looking at your drain plug photo, I didn't see enough metallic crud to think your unit was on its way out. The photo of the used oil may be different story, but it's hard for me to tell.
    If replacing or rebuilding is not too big a burden for you, you might be wise to play it safe and do so, especially if about to embark on a trip. But without knowing more of the bike's history (when was the rear drive last flushed?) I might be tempted to let it go awhile.
    Quote Originally Posted by JeffDiCarlo View Post
    I have examined several drives at different stages of failure. Jeff is right in the observation of the totally failed drive but the explanation is not exactly correct. The failure mode starts with a slight fracture in the thin hard surface of the inner or outer race of the big ball bearing. The fracture is most often caused by the bearing going metal-to-metal to hard or too often. The fracture soon turns into a chip, leaving a pit in the race. Now as the balls come around and hit the little pit the balls are damaged. Soon the damaged balls are further damaging the races. Eventually one of the balls will jam in a pit and the rest of everything comes around and like a train wreck the balls jamming together destroy the cage and all the balls wind up on one side of the bearing. The earliest sign of failure is the detection of a solid little steel flake broken off the damaged race. You might also see a lot of gray metal sludge which is material worn off the balls.
    By the time the cage breaks and the little bearing "train wreck" happens you don't need to examine drained oil to know it broke.
  1. '06 RT Final Drive Oil Change
    By C172MyP51 in forum Hexheads/Camheads
    Last Post: 07-31-2012, 06:37 PM
  2. final drive oil change on 09
    By dpmonk in forum Hexheads/Camheads
    Last Post: 05-23-2012, 12:06 PM
  3. 2000 K1200RS Final Drive oil
    By stevepage1@windstream.net in forum Flying Brick K-bikes
    Last Post: 03-19-2012, 12:22 AM
  4. Final drive leak with beautiful pictures!
    By BEEMERCHEF in forum Oilheads
    Last Post: 06-19-2008, 10:53 PM
  5. Final drive oil change
    By dorongrudo in forum Oilheads
    Last Post: 11-30-2006, 01:08 AM
