Results 1 to 7 of 7
Thread: Preferred tire demount/mount bar
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    I am continuing to make improvements on my harbor freight changer and am considering purchasing a good demount bar. Which one between the No Mar and MoJO unit seems to work the best. They both are about the same price.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Concours
    A while back there was a lot of discussion on tire changing on this forum - link follows. Seems whomever was hosting my photos has gone away.
    https://forums.bmwmoa.org/showthread...-tire-changer)
    I have both the mojo tire lever and the no-mar tire lever. The mojo lever is useful for demounting a tire; I have never been able to use the lever to mount a tire.
    https://www.mojotiretools.com/mojoweb.htm
    The No-mar lever has been used for both demounting and mounting a tire. I find that I still resort to some long tire irons to help the last bit of tire get over the rim.
    http://www.nomartirechanger.com/Moun...SABEgLRhfD_BwE
    If I was just getting one, it would be the No-mar lever. I still prefer Ru-glyde over the lubricant stuff that no-mar sells to mount/demount tires.
    AZ
    Nomar is awesome
    MOA #107139
    RA #28511
    GlenFeld
    Mar 2013
    Fowler, MI
    I have the Mojo bar and it's always been hard to use for mounting. Dismount - works well. Maybe if I used it a lot, I'd have a better technique/luck, but most times the second bead slips over / above where the 'handle' is welded to the bar and I have to begin again, or just resort to levering the tire on. The first bead is usually not a problem - many time I just push it in place once an opposite side of the bead is positioned in the valley. When installing the second bead is when the fun begins and the bead slips out of place when sliding the bar around the rim.
    I've used the No-Mar 'Yellow thing' bead holder to try to get the opposite bead into the valley of the rim, with limited success. I wonder if the 'handle' needs to have a bit of metal welded to it, to raise the 'handle' higher so that the bead doesn't slip over. Also, maybe if the 'arm' of the Harbor Freight motorcycle changer was not in place I'd have more success. It becomes pretty difficult when installing a tire with a stiff sidewall. Watch the videos of the Mojo bar in use - they seam to be able to make it work, so much of my issue may be technique. Good Luck.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I have the NoMar bar. Excellent for dismounting, not worth the effort for mounting. Easier in my opinion to use heat, lubrication, Yellowthing and a pry bar.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Aug 2016
    Reno, NV
    While I was looking at the NoMar and the MoJo unit this other tire tool came up as a non scratch choice. A bit more expensive but the mounting end is shaped much like the tire tools for my old manual Coats tire changer, has a nice hook and guide on the end. Anybody ever tried this unit?
    http://www.etoolpros.com/automotive-...oaAigDEALw_wcB
    Maryland
    I found a youtube video on the no-scratch. It looks good but since I already have the no-Mar I don't think I will change.
    https://www.youtube.com/watch?v=d2jAoI5xMwk
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
  1. preferred tires for K 75S
    By KARSTEN in forum Flying Brick K-bikes
    Last Post: 09-13-2016, 11:49 PM
  2. Anakee tire mount PSI
    By ind1mrg in forum Oilheads
    Last Post: 04-14-2013, 06:27 PM
  3. Replies: 1
    Last Post: 01-01-2013, 02:39 PM
  4. Manual help? PDF preferred....
    By CaptDistraction in forum Oilheads
    Last Post: 08-11-2009, 08:44 PM
  5. USD $45 per tire to mount?
    By eric2 in forum Campfire
    Last Post: 07-03-2003, 05:26 AM
