Results 1 to 8 of 8
Thread: 2013 K16GT 1500mi
    2013 K16GT 1500mi
    I'm a new member and this is my first post. I currently have an 07 K1200GT (had it for a little over a month). A 2013 K1600GT with only 1500 miles just appeared for sale locally. I have perused the forums and have read that some of the early K16 issues (switch gear, water pump) were addressed in the 2014 model year. So I'm wondering if this could be a jewel or should I stay away? Asking price is just under $14K.
    Your thoughts?
    Thanks,
    Charlie
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Those issues were probably addressed under warranty.
    A dealer could run the VIN and confirm.
    I'd buy it without hesitation.
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Registered User story's Avatar
    Sep 2013
    Redding, Ca.
    Welcome to the forum.
    I have a 13' Gtl with 36k miles. I've had the cooling fan fail, under warranty, one of the 6 ignition coils is starting fail other wise it's been trouble free.
    I also have a 07 K12gt with a side car. One of the cam's failed without any other damage at 54k miles.
    The K16 is the big brother to the K12.
    I bought the K16 to replace a Goldwing. The K12 with the side care is not comparable with a stock K12 without side car.
    So I can't comment on the two in a bike comparison.
    Enjoying life in the beautiful state of Jefferson
    2013 K1600GTL : 2004 VTX1800c : 2007 K1200GT with Hannigen sidecar
    Biker gunnert's Avatar
    May 2008
    Catlett, VA
    Switches and water pump should have been replaced under warranty. As noted in previous post, get the VIN, contact your local dealer and ask him what has been done to this bike. If you "like" the K1200GT, you'll LOVE the K1600. I had an '07 K12GT, worst bike I ever owned. Went from that to a K1300GT, BEST bike I ever owned. The K1600GT/GTL is the ultimate long distance, 2-up sport tourer. Little to nothing in common with the K12...
    Duane
    NoVA
    '12 K1600GT
    my 1600 GT
    I have a 2013 1600GT with 53k miles on it.....No issues to date...Just don't over fill the oil on ur changes cause it will suck it into the air box and smoke to beat hell......Has always had Amsoil in both ends,Using Avon 3d-XM tires both ends usually get right at 15,000 miles from them.....I ride solo and normally get 270-285 per fuel fill general riding....Change my own oil both ends and the Air filter, valve checks go to the dealer.....I think I could do the Brake Bleed but haven't attempted that yet....I came off two 1800 Gold Wings to the Beemer....I'll probably stay with BMW in the future but not sure if I can get away from a multi.cylinder bike....I'm 66 so will see what the big guy has in store for me.....Ride Safe out there!!!
    Fast forward to 2/ 2018 bike has 53500 miles and is in the shop for oil sucking into air box...Shop tore it down has 3 cracked pistons and there are not parts available to fix it....BMW at its best is ignoring the problem just like the driveline problems they had a few years back....make sure you have warranty and be prepared to be with out ur bike for two months because this BMW service from Germany and they don't care!!!!Pistons are backordered and no time line is mentioned!!!!
    Registered User ras100's Avatar
    Jun 2006
    Cathedral City, CA
    I owned a 2012GT for 4 years and loved it. A problem for many of the early 1600s was the switch gear. I had both left and right replaced twice. If I'm not mistaken, they will be replaced even though you're out of warrantee - possibly under a recall. A concern for me is that the bike wasn't ridden enough and may have been sitting for long periods. If that's so, and proper gas treatment wasn't added, you could have fuel pump issues. Just a side note, if you buy the bike I would replace the tires. The original Metzlers weren't really proper K1600 tires and wore out quickly. At 5 years they may be aging out. If the price id right, I would go for it.
    2015 K1600GT (Black Beauty)
    2012 K1600GT (Big Red)
    Angry
    Quote Originally Posted by cdavis View Post
    Your thoughts?
    Thanks,
    Charlie
    Not sure about 14's and newer but they are having a piston cracking problem with 12 and 13 at around 40K miles....BEWARE!!!!BMW will not support this problem if out of factory warranty and many extended are now baulking on it as the problem is affecting more bikes.....Mine has been in the shop over a month and extended warranty is running me around as they don't want to pay,GO figure....Take this for what its worth but if you have ridden your K16 very much B E W A R E !!!!!!
    May 2008
    Catlett, VA
    The piston issue was with the '11-'12 K bikes, not '13.
    Duane
    NoVA
    '12 K1600GT
  1. Michelin P4 GT Wear on K16GT
    By ch2ous in forum Straight 6 K1600 GT/GTL/B
    Last Post: 08-02-2016, 02:22 PM
  2. 2013 rt
    By Motodan in forum Hexheads/Camheads
    Last Post: 07-31-2013, 02:21 PM
  3. From RT to 2013 GS LC
    By Hammam in forum Hexheads/Camheads
    Last Post: 03-04-2013, 11:07 PM
  4. 2013 is where?
    By gene36542 in forum Rally Forum
    Last Post: 07-22-2012, 03:53 PM
  5. Topcase for K16GT
    By EMSimon in forum Straight 6 K1600 GT/GTL/B
    Last Post: 05-01-2012, 05:29 PM
