Results 1 to 15 of 16
Thread: front tire wear
    front tire wear
    Hi everyone,
    I'm new to this, first time post. I was wondering how many miles people are getting out of their front tire being the michelin pilot 4 gt. I've got 8000 on mine and the tread still looks good but the sides are looking worn. Just to have something to compare it to. thanks
    Aug 2014
    Lakeland,FL
    Got 10K on my latest and it still has life. Have found running them at 40 psi helps reduce cupping also.
    Quote Originally Posted by jfoster View Post
    Hi everyone,
    I always change the front tire when I do the rear tire usually at 10-11,000 miles and I also run 40psi in the front tire to help it wear better . I could probably get another 4-5,000 miles on the front tire but choose to replace both at the same time.
    Registered User gsinnc's Avatar
    Charlotte, NC
    Ditto to what the others have stated!
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2012 R1200GSA Magma Red!
    2016 R1200RT- Platinum Bronze
    Aug 2013
    Bedford, Nova Scotia
    While tire mileage can be relatively stated as being between 8,000 - 14,000 miles for most of the top-tier touring tires today, the difference between the lower end and the upper end is often a function of tire pressures and riding style.
    Most folks are using 2-4 psi above the Riders Manual recommendations to get the longest wear and best wear patterns. Spirited riding naturally accelerates tire wear. Down-shifting vs braking for corners (which I do a fair bit of) moves tire wear off the front tire to the rear. I only got a little over 6,000 miles out of the OE Z8s on my RTW before they corded. I had a very heavy wrist over that initial period so I was okay with that as I expect that under more "normal" riding they'd give 10k~ for me.
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    9k per set sounds right, in fact I just had my fourth set (all Pilot4 GT) mounted at 28K.
    Cycl2day Cycl2day's Avatar
    Mar 2009
    The Berkshires
    Tires Tires Tires
    I would have been a happy camper with 8k. Just told by my dealer today that my Michelin Annakees were toast with only 6,100 miles. To make things worse, I needed brake pads (almost steel on steel) on a bike that I bought from them in January. And yes I rode 6000 but really! How bad were those pads in January?
    Charlotte, NC
    Quote Originally Posted by Cycl2day View Post
    Heck never mind the tires if you need brakes after 6100 miles that is crazy!
    Ed Apelian
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    My Anakee III's have 12.5K miles on them and are still legal with no cupping front or rear.
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    How many miles?
    I normally get around 4K rear and 6K front on my 2014 GS. I switched to Shinko 705 and still get about 4K on the rear, but nearly 10K front! They stick just fine and great on fire roads at a price I can afford every couple months!
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    That means you're having fun
    Welcome to the forum.
    Lee
    2016 R1200RS
    MOA # 30878
    How many Miles
    Heavy mountain riding in the Sierra foothills with my new RS had the OE Z8 front tire go away after 4500 miles. Lots of downshifting and braking, not much straight line riding. Going to the new Metzler 01 Roadtec's this coming week. I tend to weight bias the front end when riding and really appreciate a sticky tire...........
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    I'm on my first ever front PR4T, it has 9,500 miles and plenty left. I've had 2 PR4Ts on the rear, one got 6,700 miles, the other 11,700. No idea why the huge difference. It's looking like PR4Ts may be like Anakee 3s - 2 rears for every front.
    And for the guy who got 6,100 on brakes, if it's a new bike something is seriously wrong. I got 35,000 on each of my first 2 sets of rear pads, and I changed the front at 43K; 38K later it looks like they'll need replacing soon.
    2016 R1200 GSA
    Mar 2009
    The Berkshires
    Ok, I need to be more specific. I bought the bike used with 23k on it in January 2013 and they put new Annakees on it then, or at least they said that and they appeared to be new. In October 2017, after 6k this year they said the tires will not pass inspection and the brakes are metal on metal (but didn't get to the rotors yet!). So my thoughts are that they may be a bit quick to kill the tires (but rolling the dice there is dangerous and they know that) and the brake pads are gone but probably should have been done before they charged me top dollar for the bike.
    p.s. bmwbob - how are those 705's on the open road?
    Charlotte, NC
    Well that seems a lot more reasonable! While needing brakes at 29K is still a bit early it is much more understandable. In addition my buddy who has a GSW indicated the OEM brake pads had a known "early wear out" issue. I believe he too had to replace the pads before 30K. I agree .... just bite the bullet and get new brakes and tires and know you are safe.
    Ed Apelian
  1. Uneven front tire wear
    By demingoutwest in forum Oilheads
    Last Post: 11-01-2016, 07:01 PM
  2. weird front tire wear
    By arsprod in forum Oilheads
    Last Post: 08-05-2011, 12:10 AM
  3. Front Tire wear
    By ARM74 in forum Oilheads
    Last Post: 07-16-2008, 01:59 PM
  4. Front Tire Wear 1100RT
    By jbedone in forum Oilheads
    Last Post: 10-28-2006, 03:18 PM
  5. front tire wear
    By TRJeff in forum Oilheads
    Last Post: 10-10-2003, 01:11 AM
