Results 1 to 8 of 8
Thread: ESA Question For All You Smart Guys Out There
    Left Coast Rider
    Nov 2011
    Scenario:
    Lets say someone disconnected the damping adjuster plug from the front shock to the main harness.
    Situation:
    Upon reconnection, one does not recall the damping position the front shock was in before some dumbass disconnected the wiring. The front shock could have been set on "Comfort" or "Normal" or "Sport".
    Challenge:
    How does one ascertain/adjust the front damping to match what is displayed on the ESA readout / and what is applied to the rear shock? I'm fairly sure that the front shock is set on Comfort while the readout and rear shock are on Normal.
    So, will the wise minds which have been so helpful in the past kindly chime in?
    Disclaimer: I may or may not have been the dumbass.
    Calgary
    The GS-911 tool allows you to calibrate the ESA. A dealer would also be able to do it for you for a fee.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Sep 2006
    CENTEX USA
    I don't think any foul there. Now, if you are sending an ESA shock off to a shop, they will want you to set it in a certain position for their reference...but never recall being told to not touch buttons prior to a reinstall. Thinking the ECU stored that info and just plug it back in and ride.
    One of the shock guys may chime in with more info, but have removed a few following model specific factory shop manual and do not recall any wording about setting in a certain mode.
    BTW, left my S in Sport/one helmet most it's life unless having to plod on an Interstate for miles. Comfort was just that...marshmellow soft and no fun in the twisties
    Steve Henson
    Left Coast Rider
    Nov 2011
    Thank you, Gentlemen. I hear what you're saying about the "Comfort" setting. When set in that mode it feels like I'm riding a pogo stick instead of a motorcycle.
    Left Coast Rider
    Nov 2011
    Issue is, since I accidentally (yeah, that's it, "accidentally") unplugged the thing, I've been riding the bike...and futzing around with settings.
    I'll try the GS-911 thing and report back.
    Apr 2016
    Seattle
    I would think the shock would adjust to whatever you have the setting set to when you plug it in and provide voltage.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    Calgary
    Quote Originally Posted by daboo View Post
    Chris
    This is what I understand to be the problem with that. The computer only knows that there are X number of pulses from minimum to maximum limits of adjustment of the pre-load. It does not know where the actuator is at except by how far it was moved from one of the two limits. Calibrating it lets it reset the actuator to a known position and defines the limits so it can figure out where to move it when a selection is made.
    Left Coast Rider
    Nov 2011
    Alrighty then....we have the procedure to reset preload. Is there a procedure to reset damping? I'm fairly sure that my front rebound is "one step behind" the rear rebound. i.e. When the rebound is set to "Sport", the front is on "Normal".
    How does one ensure that both front and rear rebound adjustments are in synch?
    Thanks again, guys.
  1. I got a smart phone
    By Newstar in forum Campfire
    Last Post: 05-14-2010, 09:21 PM
  2. How smart is Your Right Foot ?
    By BUDDINGGEEZER in forum Campfire
    Last Post: 10-16-2007, 02:07 PM
  3. Do I feel smart or what?
    By YELLOW_S in forum Campfire
    Last Post: 04-30-2007, 01:16 AM
  4. If I were a smart man
    By Friedle in forum Campfire
    Last Post: 09-28-2005, 04:45 AM
