Results 1 to 7 of 7
Thread: Shifter Linkage Lube
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Ok wanted to do this for awhile now so got it done today.
    If you had a LT the clips for releasing the linkage is the same. If you never touched one of these look at it carefully before you try. They look like this:
    I removed the shifter lever also:
    So you see this stuff is taking a little bit of abuse, On the picture with the shifter and bolt laying there that brown is really a washer that is rusted that color.
    This is how it looked cleaned up:
    I used Honda Moly on all cups and balls. Also on the frame where that washer rides and the shifter bushing. I was happy with the outcome and feel it is a worthwhile maintenance task.
    One thing when I was changing my rear wheel over yesterday I spied another linkage set but with plastic covers. So I pulled the left little triangle cover off with the three pegs and grommets and there it sits. The top is held on with a 10MM nut and the rear is a stud with a 10mm wrench fitting. The thing that surprised me is it was in worse shape then the shifter linkage itself. I cleaned it and loctight the nut back on after using liberal dose of Honda Moly
    I really took no pictures except this one and to be honest I have no clue what it operates yet but I will. It was in bad shape.
    Again not saying you need to do this but maintenance is maintenance.
    YMMV
    Lee
    2017.5 R 1200 GSW
    Mansfield,MA
    Nice...Thanks
    I'll add it to the DIY index- https://forums.bmwmoa.org/showthread...Mods-and-DIY-s
    Mod Squad
    2009 F800GS 1994 TW200
    Oct 2016
    Harrisburg, PA
    Nice...Thanks
    Thank you.
    I am happy to contribute for all I have received here.
    Lee
    2017.5 R 1200 GSW
    Oct 2016
    Harrisburg, PA
    I have been told the plastic linkage is the rear level sensor. Need to find the front one and do it also.
    Lee
    2017.5 R 1200 GSW
    GlenFeld
    Mar 2013
    Fowler, MI
    Quote Originally Posted by LFarling View Post
    YMMV
    Yes. not everything is spelled out in the service manual and a little thought based on life experience can allow a MC to last a very long time.
    Nicely done - thanks.
    YMMV
    What year is the bike?
    Sent from my SM-G920W8 using Tapatalk
    Oct 2016
    Harrisburg, PA
    As it says in my signature it is a 2015 R1200 RTLC in San Marino Blue.
    Lee
    2017.5 R 1200 GSW
  1. Shifter linkage question
    By navigator16 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 01-27-2016, 06:43 PM
  2. Shift linkage
    By Jade in forum Oilheads
    Last Post: 08-06-2011, 02:47 PM
  3. shifter linkage?
    By 26667 in forum Airheads
    Last Post: 09-11-2008, 12:35 AM
  4. Shifter linkage adjustment
    By DFNTON in forum Flying Brick K-bikes
    Last Post: 07-17-2007, 11:50 PM
  5. Shifter linkage loose on 99 RT
    By Bdiver in forum Oilheads
    Last Post: 05-20-2005, 03:27 AM
