Results 1 to 14 of 14
Thread: Charging Battery Through Powerlet Port
    Left Coast Rider
    Nov 2011
    Is there any reason why I can't/shouldn't/wouldn't want to do the above with a Battery Tender Junior? It works like a charm on my 1100S however I can't seem to do the same on the K1200S. Has it got something to do with the CAN-bus system?
    Thanks in advance, folks.
    Sep 2006
    CENTEX USA
    On our 05's, had to turn key on to initiate outlet, plug in charger, then turn key off. I have the BMW cube charger and it will not initiate w/out key on
    The outlet shuts down after a short period...it's why some folks aftermarket lights stay on for a few seconds if they used that as a relay trigger point. A SAE lead from battery takes that dance away on Battery Tender models.
    Steve Henson-Mod Team and club tire changer
    Mansfield,MA
    As Steve says, SAE connector and skip the confusion
    Mod Squad
    2009 F800GS 1994 TW200
    Left Coast Rider
    Nov 2011
    I attached an SAE lead to the battery but all that extra weight is bugging me.
    I tried the key on - plug in - key off thing but, as Steve points out, the port turned off after a few seconds. I guess I'll have to contend with the simple solution.
    Thanks guys.
    Registered User selyab's Avatar
    Sep 2009
    PNW
    There are a couple of other options beyond the dedicated SAE connector wired directly to the battery.
    1) BMW produced chargers that kept the CANBUS from shutting down. Mine is 2007 vintage but it is just a straight charger and does not have the smart charging technology of the Battery Tender. There might be newer models that are more sophisticated.
    2) You can replace or add another Powerlet/BMW style connector that goes straight to the battery. Powerlet makes several kits for this. Another advantage is that you lose the amperage limit of the normal CANBUS outlet which allows you to use heated gear that exceeds the CANBUS controlled limited. Downside of course is that everything will continue to draw after the key is off.
    On my GS, I put a plug on the very long Garmin cord of my GPS and snaked it down to my CANBUS plug below the seat because it is not useful for charging/heated gear to me. It stays plugged in. That way my GPS will not continue to draw and I don't have to turn it off and for quick stops the GPS remains powered for making adjustments with the key off. If you added a second plug (some bikes provide space for it and can be provisioned for dual outlets) you could use it for this purpose.
    Now go riding since the fires have gone out in BC!
    Current : '76 R90/6, '11 R12GSA, '15 RTW, '16 S1R.
    Gone: '07 K1200GT, '03 R1150RT, '85 K100RT.
    Schmails
    Jun 2015
    Outside Philly, PA
    The Optomate 4 charger has a dual program and supports CANBus. I have one on my ‘10 RT.
    Great charger. Just need the Powerlet Adapter.
    OptiMate 4 DUAL PROGRAM Battery Saving Carger, Tester, and Maintainer https://www.amazon.com/dp/B001EBDXLM..._0-4Xzb59SYEX8
    Greetings from the Philadelphia Suburbs.
    '11 R1200RT Ostra Gray
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by schmails View Post
    +1 - bought one a few years ago from Revzilla for my 07RT and use it through the rear powerlet just fine.
    Mansfield,MA
    Quote Originally Posted by mikegalbicka View Post
    Wasn't there some special instructions on that charger- to go from "regular" charge mode to "canbus" charge (through powerlet)? As I recall, some had some confusing instructions.
    Mod Squad
    Schmails
    Jun 2015
    Outside Philly, PA
    You turn it on with the wires shorted for 10 seconds. After that it changes modes.
    Just switched it to charge my ‘zuki.
    —ChrisD
    Mansfield,MA
    —ChrisD
    Beyond that, the mode indication was part of the confusion.
    Mod Squad
    Aug 2014
    Lakeland,FL
    Like most things today a careful read of the manual can be the most confusing part of using something!
    It does tell you how but not as clearly as it could.
    Schmails
    Jun 2015
    Outside Philly, PA
    I’ll admit. It’s confusing.
    In CANBus mode, it does a weird flicker of the yellow lights every 10 seconds. Regular mode, not.
    In CANbus mode, it constantly catches my attention.
    Not putting those mode lights on the front saved them $0.80 per unit. SMH.
    —ChrisD
    Mansfield,MA
    —ChrisD
    Sounds like you guys have a good understanding of the charger
    Maybe the two of you could get together and post a DIY for the forum?
    Gary
    Mod Squad
    Aug 2014
    Lakeland,FL
    Gary
    I bet Chris could get it done without any help from me.
  1. Battery charging
    By jaflowers in forum Wetheads
    Last Post: 08-19-2015, 04:28 PM
  2. Replies: 13
    Last Post: 07-23-2011, 10:33 AM
  3. Battery Charger port? R1200RT
    By drummer in forum Hexheads/Camheads
    Last Post: 01-29-2011, 04:41 PM
  4. Powerlet port on 2004 R1150RT
    By jdwatson in forum Oilheads
    Last Post: 07-15-2010, 10:43 PM
  5. R1200C Battery port?
    By james1300 in forum Oilheads
    Last Post: 04-04-2009, 03:10 PM
