Results 1 to 3 of 3
Thread: side stand switch
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    side stand switch
    Hi Guys, the question of the day is has anyone linked out the side stand switch ? I find it diffcult to deploy the side stand with the wife aboard due to the double spring,which I think is there to make sure the stand doesnt drop and cut the engine if one or both springs break, I have oiled the pivot etc what I am thinking is link out the switch and remove one of the springs !thanks in advance Jimmy, PS going for a wee ride between school bus runs ,
    Mansfield,MA
    From threads I've seen, the general consensus is leave all aspects of the side-stand intact and functional.
    If the stand drops or if a rider is to ride off with with the stand down, the next sweep or turn to the left ejects the rider. It's ugly.
    Perhaps you can practice your wife getting on after you get on. She can use the left passenger peg while she grabs your shoulders.
    Mod Squad
    2009 F800GS 1994 TW200
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    What Omega man said.
    The switch is a safety device and should not be defeated.
    The SS is to be greased, not oiled. There is provision to do this with a pin grease gun thru a wee hole on the side stand mounting bracket.
    Ufda happens..........
  1. Side Stand Switch
    By RTGS0314 in forum Oilheads
    Last Post: 05-24-2016, 02:43 PM
  2. Side Stand Switch
    By Paul_F in forum Oilheads
    Last Post: 10-07-2011, 04:00 PM
  3. Side stand kill switch
    By wzellwzell@yahoo.com in forum Oilheads
    Last Post: 09-24-2010, 02:31 AM
  4. New Member - Side Stand Switch Fix
    By LGS930 in forum Oilheads
    Last Post: 01-23-2009, 12:21 PM
  5. Side stand switch
    By 85343 in forum Oilheads
    Last Post: 10-22-2005, 03:30 PM
