Results 1 to 6 of 6
Thread: Anti Seize ? 2014 R1200RTW
    Registered User wkuwiz's Avatar
    May 2014
    NW arkansas
    Hello and Thanks!
    Quick questions: 1). Is there any difference in using copper anti-seize vs. aluminum when re-installing the bolts on the front brake calipers (after tire change).
    2). What is the torque setting? Does to change w/ AS?
    3). Should i be using anti-seize at all since the bolts look dry?
    Cheers!
    CW
    '06 F650GS Dakar, 2016 K1600GT
    See you on down the road!
    Fastman Fastman's Avatar
    Webster Groves, MO
    I would not be using anti-seize on those bolts. Reinstall them dry. Torque value should be in the owners manual (in the section about changing the front tire).
    Sent from my iPhone using Tapatalk Pro
    Fastman
    '86 R65, '96 R1100RS, '04 K1200RS, '13 K1300S 30th Anniversary - SOLD
    '16 R1200GSA
    The most notable thing you can leave for posterity is your name...signed Anonymous
    Mansfield,MA
    Some more info in this recent thread-
    https://forums.bmwmoa.org/showthread...stalling-wheel
    Mod Squad
    2009 F800GS 1994 TW200
    May 2014
    NW arkansas
    Quote Originally Posted by Fasterling View Post
    Thanks. Looks like 38nm.
    CW
    May 2014
    NW arkansas
    Good Link Omega Man. I alway like Henzilla's advice. Light grease on the axle and wire brush the threads. I had been steered by a YT video and thought to ask.
    CW
    CW
    Aug 2013
    Bedford, Nova Scotia
    Yes, using any anti-seize or other product changes the torque values. Sometimes by a significant margin.
    Those bolts are meant to be installed clean and dry.
    Torque for the M10x65 bolts is 38 Nm
    As far as the general part of your question "any difference in using copper anti-seize vs. aluminum", I use copper anti-seize only (in the few places that I use any anti-seize), as I have found it seems to work best for me, however, that is only anicdotal and I have nothing but past experience to support it.
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
  1. Anti-Seize use?
    By garlicbreath in forum Hexheads/Camheads
    Last Post: 05-24-2016, 12:59 AM
  2. Anti-seize R75/5 questions
    By jbf in forum Airheads
    Last Post: 05-15-2013, 10:59 PM
  3. Plugs anti-seize or not
    By 140008 in forum Airheads
    Last Post: 06-27-2012, 01:41 AM
  4. Anti seize
    By georgej in forum Airheads
    Last Post: 06-15-2012, 04:52 PM
  5. Anti-seize compound
    By fracture in forum Hexheads/Camheads
    Last Post: 08-11-2008, 10:25 PM
