Results 1 to 4 of 4
Thread: 2005 R1200RT Misfires at high throttle
    Wow ... what a puzzler ... 2005 R1200RT begins to stall and sputter whenever given about 3/4 to full throttle, very frustrating! ... myself and local dealer have checked the obvious suspects:
    1. Air intake obstruction
    2. Drained fuel and replaced with fresh
    3. Swapped fuel injectors with known good ones
    4. New spark plugs
    5. Swapped ignition coils with known good ones
    6. Swapped with known good fuel pump and fuel pump electronics
    7. Checked cam position sensor
    8. Adjusted valves
    9. Adjusted throttle body sync
    Can't figure out why this bike is acting this way ... has anyone experienced this issue? ... could sure use some experience here ... thanks!!
    John
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Blocked fuel line, can be either inside or outside the tank
    Blocked exhaust
    Blocked vent line to the gas tank, causing a vacuum which then inhibits fuel flow
    Blocked or wet charcoal canister or the lines to it
    Cracked vacuum line, allowing too much air to be sucked in
    QUESTION: When this happens, do any of the lights or instruments flicker? That would indicate an electrical problem - flaky battery, loose connection, etc.
    It sounds like a blocked fuel filter to me. More or less a classic symptom.
    The problem is resolved. After taking the bike back to the dealer, and putting another 8 - 10 hours of troubleshooting into it, it was finally discovered that it was actually both coils (not sure if primary or secondary) that were intermittently bad. So, originally swapping out one coil at a time to troubleshoot the problem was not adequate to isolate the issue.
  1. 2005, R1200RT, Can't Sync throttle bodies.
    By Spinakr in forum Hexheads/Camheads
    Last Post: 03-19-2013, 08:22 PM
  2. High Idle Throttle Sync
    By BBKME in forum Oilheads
    Last Post: 08-28-2009, 02:49 PM
  3. throttle body sync- high speed adjustment rpm?
    By tomrogers in forum Oilheads
    Last Post: 08-07-2006, 07:30 PM
  4. Sticky throttle when heated grips on 'high'
    By jacco in forum Oilheads
    Last Post: 04-29-2005, 02:38 PM
