Results 1 to 3 of 3
Thread: Wiring for K1200GT Low Beam
    Aug 2017
    Hudson, MA
    My xenon bulb burned out. I found the quick access cap and replaced it, but now the low beam does not work. It looks like it is powered by yellow and yellow/white wires. Anybody have a clue as to where I can test it back to the battery? I traced it to a bundle of wrapped wires that seem to lead to the battery, but I don't really want to have to open it up unless it's the only way.
    Bob
    Current 2007 K1200GT
    Former 1999 R1100RT, 2002 K1200LT, 1996 K1100LT, 1986 R80 RT, plus a bunch of Honda, Yamaha, Husqvarna bikes... Riding since 1964
    Apr 2006
    Nibley, UT USA
    Before tearing into any wiring, I'd connect a gs911 or dealer MoDiTec and make sure the canbus is happy and allowing that circuit to power up. Also, make sure you are allowing the system self-checks to complete before trying to start the bike. On my K13GT if I rush that process it will sometimes fail to activate the HL and throws a warning lamp on the dash, tho I've not had that happen since replacing the battery...
    Best
    DG
    DGerber
    1983 R80ST -- 1988 R100GS "Bee"-- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Aug 2017
    Hudson, MA
    Wiring for K1200GT
    Thanks...good advice.
    Bob
  1. K1200GT '08 And I Can't Remove The Burnt Out Low Beam!!
    By scm54449 in forum Wedge K-bikes
    Last Post: 08-26-2016, 11:08 PM
  2. Low Beam wiring melted - 08' R1200GS
    By rjzinc in forum Hexheads/Camheads
    Last Post: 09-19-2012, 12:25 AM
  3. Low beam wiring failure
    By Mr. B. in forum Airheads
    Last Post: 01-27-2012, 06:19 PM
  4. Low Beam Headlight Out.....Wiring?
    By roch2nite1 in forum Wedge K-bikes
    Last Post: 06-02-2010, 04:20 PM
  5. K1200GT autoswitch wiring
    By ddw in forum Flying Brick K-bikes
    Last Post: 03-29-2007, 10:41 AM
