everything went back together the way it was
put brushes in my 86 R80 now it is not charging.at 11,9 volts charging light stays on. everything went back together the way it was.I did disconnected the ground cable before started work.and guesses.
Darryl Cainey: Are the brushes contacting the slip rings on the rotor under spring pressure?
