Results 1 to 5 of 5
Thread: Side cases , central locking system 2017 1200rt
    Question Side cases , central locking system 2017 1200rt
    I have exhausted the method in the owners booklet on how to detach the side cases . Seems like it should be easy enough .
    1. Key in lock . Turn to release . Push down keyed button . Flap to open case flips up . Left carry handle and remove .
    I am stuck on lifting handle . It will not budge . Either side.
    I could use some input .
    Mansfield,MA
    Welcome to the forum!
    You have gone past oilheads right to Wetheads
    One of us Moderators will move it later so we don't lose you in cyberspace with a quick move.
    Good luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Nov 2011
    Central Ohio
    Quote Originally Posted by thirdchildhood View Post
    Turn the key in the opposite direction, the carry handle pops up, lift and remove the case.
    No button pushing, no flap lifting.
    Larry
    2006 R1200RT
    Magic
    Thank you . Works great . Appreciate your time and effort .
    Quote Originally Posted by lkraus View Post
    Thanks .
    Good luck.
    Gary
  1. Adding Central Locking
    By kltk165 in forum Wetheads
    Last Post: 08-08-2014, 03:28 AM
  2. Replies: 2
    Last Post: 05-11-2013, 12:28 PM
