Results 16 to 22 of 22
Thread: Replaced the fuel strip and it worked forever after?
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    The fuel strip on my 07 was replaced in 2015 at 95,000km on BMW Canada's "Good will gesture" The extended warranty applies only to the US.
    In Canada, they treat each case independently.
    It's still holding up 48,000 km later
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Registered User jandhumphreyme's Avatar
    Sep 2013
    Central Maine
    '11 R1200r with 38K miles and having the third strip installed now. I have no illusions this will be a lasting repair nor will it prove accurate readings. I will continue to have new ones put in at every failure, not in hopes of a lasting repair, but as a reminder to the mother-ship of their obligation to quality and the consumer. Sometimes a financial sting is all people can understand.
    So often times it happens that we live our lives in chains
    And we never even know we have the key
    Registered User temesvar's Avatar
    Dec 2015
    Windsor,ON
    Quote Originally Posted by jandhumphreyme View Post
    I agree with you if have a reliable dealer near by, are retired and have not much else to do with your time. As in my case, have to take the day off work to
    ride two hours to the closest dealer. wait (providing he is willing to do it while I wait, with appointment!) at least two hours, (can it be done in two hours?)
    than ride back two hours. There goes the day, and am not sure if it is worth it.
    I'd again like to encourage people who've experienced the strip failure to report it to NHTSA/DOT as a safety issue. It is possible that some clever German engineers could design a replacement using a float and some circuitry to plug it into the existing circuit. It's been done privately. There really isn't any excuse for BMW not to - except it's less bother and cost to let the supplier of the strip pay for replacing them. The 12 year warranty on the strips will be expiring on some bikes soon. The only hope people who are in that position have is that they have a failure within the 2-year parts warranty BMW has (which does still apply to strips replaced under the 12 year warranty), and that from then on their strip fails before the next 2 year warranty period is up.
    There are very explicit directions on how to do this in the fuel-strip poll thread. If it's too much bother to look it up, I'll repeat it here:
    Quote Originally Posted by Don Eilenberger
    Here is what I filled out (after selecting the on-line form found at: https://www-odi.nhtsa.dot.gov/VehicleComplaint/) <---- LINK UPDATED 10/3/16
    • VIN: Entered my VIN#
    • VEHICLE: BMW R 1200 R 2007 (this is on the drop down screen once you enter BMW.. it's down a ways.. look for your bike if it's not there use the ones that are there as a pattern to create a new model listing.)
    • APPROXIMATE DATE: I entered the date it first happened (as the instructions say to.)
    • CRASH: No
    • FIRE: No
    • FATALITY: No
    • VEHICLE MILEAGE: I put down the approximate mileage it first happened at
    • SPEED: I put down 65 for good luck.
    • AFFECTED PARTS: FUEL/PROPULSION SYSTEM <-- this is the important one. This is how the complaints get lost.
    • TELL US WHAT HAPPENED: Fuel gauge stopped responding, leading to running out of fuel while moving. This is a common failure on many bike models from BMW from 2005-2013. I have had this happen 5 times so far, and each time the fuel level measuring strip in the fuel tank was replaced. This is an unsafe condition since loss of engine power from running out of fuel can be quite dangerous on a motorcycle.
    I then filled in my personal info.
    My suggestion - if you've experienced the failure - take 10 minutes to fill in the form... it might just help, and it can't hurt. Fell free to ignore this if it doesn't seem reasonable to you.. and I have no delusions about getting a "Friend of the Marque" for posting this up.. If anyone wants to point the K bike forum (of models that used the fuel strip) to this post, please feel free to.
    Reporting it here might make you feel better - reporting it to NHTSA can actually make something happen. They have required numerous other motorcycle manufacturers to issue a recall and a real solution for the exact same fuel gauge failure - since it's rather obviously a real safety hazard if your engine stops running in heavy high-speed traffic.
    Help make something happen - don't just complain here. You paid for this feature on your bike - it's your right to expect a faulty design should be rectified.
    Registered User selyab's Avatar
    Sep 2009
    PNW
    Fuel Strip Failures
    I replaced my own fuel strip using the GS-911 before BMW came out with the 12 year warranty extension on my 07 K1200GT. It required removing the Tupperware and the tank so not something you could wait for while a dealer performed it. Also, the strip is supposed to be bone dry when you calibrate it so placing it in a tank without letting the tank dry is not conducive to a quick job. Someone may correct me but I think the reason BMW has not done more is this is supposedly related to alcohol in the fuel so this is not a problem in Europe. The strip is just a piece of plastic with wires which I assume works on electrical capacity like large aircraft fuel systems. Of course there is no conclusive evidence that I have seen. After I replaced mine, I had access non ethanol fuel which was much more expensive but doable when I used the bike for commuting. It did not fail for the two years after I replaced it.
    Just another reason why I traded in a bike I really liked. Too many little nits to deal with that I have not had on my other BMWs. Any failures on that bike is not only a financial challenge but a technical challenge to resolve.
    Current : '76 R90/6, '11 R12GSA, '15 RTW, '16 S1R.
    Gone: '07 K1200GT, '03 R1150RT, '85 K100RT.
    I had it replaced in Aug.'17. Still going.
    Tech. told me they (BMW) redesigned it + it Should last...we'll see.
    Sent from my C6606 using Tapatalk
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by 67207 View Post
    Really? First I've heard of a redesign.
  1. Another new fuel strip?
    By drummer in forum Hexheads/Camheads
    Last Post: 03-09-2016, 03:16 AM
  2. fuel strip help... maybe
    By f14rio in forum Hexheads/Camheads
    Last Post: 10-27-2012, 02:02 PM
  3. 07 GSA -- Fuel Strip?
    By hintzir09 in forum Hexheads/Camheads
    Last Post: 05-03-2012, 06:59 AM
  4. Fuel Strip
    By bikerboy108 in forum Hexheads/Camheads
    Last Post: 10-23-2011, 01:54 AM
  5. fuel strip on GS? '09
    By dpmonk in forum Hexheads/Camheads
    Last Post: 05-04-2011, 04:08 PM
