Results 1 to 11 of 11
Thread: Weatherproof Pants On A Budget - Scorpion Seattle Overpants Review
    All-
    Is it even possible to get true four season functionality out of inexpensive overpants? Tune into the latest Moto Mouth for an in-depth review of Scorpion's Seattle Overpants to find out!
    -MKL
    Moshe K. Levy
    Moto Mouth Moshe https://www.youtube.com/c/motomouthmoshe
    1973 BMW R75/5 / 1987 Yamaha YSR50 / 2013 Moto Guzzi V7 Racer / 2015 BMW R1200RT
    Odd Cut
    I ordered the Seattke Overpants last spring as they were the only pants that hit all the points I wanted: waterproof, vented, full length zips, and able to be worn as a stand-alone pant or an overpant. I had to return them as the waist was cut ridiculously low, more like a woman's fashion pant than a protective riding pant. Beware the odd cut!
    KevinRT
    Ottawa, Canada
    Quote Originally Posted by KevinRT View Post
    I guess it depends on your build. I kind wish they sat a little lower on me!
    -MKL
    Moshe K. Levy
    Geez, just get the bottom half of BMW's Rainlock 2 rain suit.$109
    If you're riding around all the time in something waterproof, you're likely pretty hot a lot of the time.
    With separate rain pants you only wear them when you need them, and if you have mesh pants you can wear them to stop the airflow simply to keep you warm.
    Rolls up pretty small, requiring hardly any storage space.
    Two separate animals, Kent. The Scorpion pants are armored cordura pants for someone who wants to wear waterproof motorcycle pants. They're not separate rain gear, and they breathe fairly well (certainly better than nylon rain gear does.) Some people don't want to deal with rain gear, so this would be a good choice for them if they're in this price range.
    -MKL
    Moshe K. Levy
    Apr 2016
    Seattle
    It's a great review, once again. Thank you, Moshe.
    In long-term use of rain pants in Seattle commuting, I've found that rain pants with a built-in liner will eventually start leaking in the crotch. I suspect it is because the inner liner is pulled when the boot slides through -- or catches on the liner. Duct tape works great as a fix for this, by the way.
    I bought some Olympia pants years ago. At first, I thought the way they made their pants waterproof was a bother. There was a separate rain pant from the outer Cordura pant material. What a hassle, I thought. Putting on two sets of pants and as a commuter in Seattle, I needed that rain liner.
    Over time, I realized the wisdom in having a separate rain pant liner. (Note that while you can fasten the rain pant liner in with the outer Cordura pant, I leave it separate.) Putting the rain liner on by itself, takes only seconds. It's lightweight and slides without catching on the boots. The outer Cordura pant slides easily over that...easier than over blue jeans by themselves. And the liner on the Olympia pants breathes like a Goretex liner would.
    In the summer, I just roll up the rain liner and carry it with me in my bags. The outer Cordura pant has some breathability, and in the case of the Olympia pants, the thigh area unzips and leaves a mesh area for some ventilation.
    And if I ever find the rain pant liner leaking through use and age, it is easy to replace with any rain pant sold by an outdoor sporting goods store like REI or Cabella's. Replacing the entire riding pant because of a leaking liner, is no longer needed.
    I don't want to come across as knocking the Scorpion pants, just to present an alternative.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    Good video, very informative and I LIKE the Guzzi!
    The pants seem like quality gear to consider....Thanks for posting.
    Ron Prior {AMA member ,MOA member}
    Milford,Oh
    2002 KLT
    2004 Roadster
    Hi Chris-
    I feel as you do. For my personal gear, 3 seasons, I wear non-waterproof (armored) motorcycle pants (Motoport) and I carry rain gear "just in case." In the winter most of the heavy stuff is waterproof anyway, so no need for rain gear then. Sometimes my opinion changes based on the gear I test, and in this case I was pleasantly surprised by the performance of these pants at this price range. Someone with $230 or so can feel good about buying these instead of dropping more coin on separate garments.
    -MKL
    Moshe K. Levy
    Apr 2016
    Seattle
    One of the things I noticed about these pants that I liked, is the reactive armour. The vents and waterproof pockets are nice as well. They are good pants for someone in the market for something new. Like you, I rarely wear rain gear anymore, even though I ride all year round, as long as it isn't snowing. It isn't hard to find good quality gear that has waterproofing built into the design.
    Question...what do you do with this gear when you're done with the review? If you have Motoport gear, I can't see you leaving that in the closet to wear this new gear.
    Chris
    John 14:6
    Quote Originally Posted by daboo View Post
    Chris
    Hi-
    I generally put the test gear on my commuting duty for at least a season (less expensive gear) and sometimes over a year (for more expensive gear.) My commute is 107 miles per day. So you'll note most of my tests (video and print) say "after X months / miles" so that the viewer / reader knows what kind of test I've put it through. I really do test this stuff - I'm not rewriting the manufacturer's press releases or running it for a few weeks, because that's just not long enough to really see how stuff holds up.
    You asked what happens at the end: Several things. Some manufacturers want the gear back, because it's expensive and they can sell it, even used. Some don't want it back and in that case, it becomes either property of the magazine, or mine, depending on the publication. In general, the more expensive things are, the more the manufacturers want them returned after testing is complete.
    -MKL
    Moshe K. Levy
  11. 09-14-2017, 12:22 AM
  12. #11
    AZ
    I really like the First Gear "shell" pants. Light and simple, but water and wind proof.
    MOA #107139
    RA #28511
  1. Replies: 0
    Last Post: 10-09-2016, 06:53 PM
  2. REV'IT Tornado Mesh Jacket and Pants Review
    By robert.bantly in forum Gear
    Last Post: 08-01-2012, 12:45 PM
  3. Review...Scorpion Hi-Vis
    By JDOCKERY132445 in forum Gear
    Last Post: 10-11-2011, 10:01 AM
  4. waterproof pants that aren't overpants
    By briana in forum Gear
    Last Post: 08-13-2011, 03:55 AM
  5. Scorpion XDR Pants
    By trident74 in forum Gear
    Last Post: 02-06-2009, 12:34 PM
