Results 1 to 8 of 8
Thread: F650ST (Funduro) Leak
    Jun 2017
    Salt Lake City, Utah
    Most learned BMW owners, I have a possibly dumb question about a leak/drip on my 1998 F650ST (Funduro) that I hope you might be able to help me with. It appears to coming from the rear most tube of the ones connected to the evaporative canister but it looks and feels like oil. Just started and happens after I've been riding and the bike is hot. Any ideas what this is or what could be causing it? Thought I'd ask before bringing it to the repair shop for no reason. Thanks.
    __________________________________________________ ____________________________________
    After 27 (long) years off I'm back to riding - finally! Just bought a new 2017 F700GS in "Racing Red" - Loving it!
    Jul 2018
    Corralitos, CA - Santa Cruz County
    That bike is so clean and perfect. Looks brand new.
    Apr 2019
    Sparks, Nevada
    Quote Originally Posted by excdnguy View Post
    Any luck on what was going on with the oil leak? My 2000 F650 does the same with gasoline - all three of those tubes seem to be overflow. I'll do more investigation this evening and next... My garage smells like gas now
    Scott
    Jun 2009
    Rochester, MN
    Quote Originally Posted by nvbeav View Post
    Scott
    My bet is a stuck float bowl... I'd isolate each tube separately into 3 different containers, then you can accurately see what is coming from where.
    Apr 2019
    Sparks, Nevada
    Quote Originally Posted by drneo66 View Post
    I'll see about getting some urine sample bottles from my doctor at the next visit -- this sounds like a much better use of them
    Is un-sticking the float bowl something a noob like me can fix? I'll definitely read through the owner's manual and check out youtub...
    Thanks for the input!
    Mansfield,MA
    How is the smell- like bad gas? How does it feel- like oil? Do you get more after a short ride or long ride.
    To me it looks like the crap that can drip out of an emissions system......especially the older systems.
    Mod Squad
    2009 F800GS 1994 TW200
    Jun 2009
    Rochester, MN
    We didn't ask, but how much is coming out?
    If it's a drop or two, as OM said, it's probably blow-by from the emissions system. If it's a good-sized puddle, then further investigation is needed.
    https://www.youtube.com/watch?v=b_iJpEbCk5U
    and
    https://www.youtube.com/watch?v=p44VNddZ7Zc
    Apr 2019
    Sparks, Nevada
    and
    Those are informative links. Watched a few of the guy's videos, but I'll have to get some hands-on to let it sink in.
    I've got gasoline coming out when I shut off the engine - maybe an ounce - making a quickly evaporating puddle. If I shut off the gas valve and let the engine run for a couple minutes to use up the gas in the line (float bowl?), it doesn't leak (or appears not to leak).
    The original person who posted had oil leaking - mine doesn't appear to leak any oil.
    Scott
  1. '97 Funduro, Flooded Air Box
    By VTGS1200 in forum Thumpers - F & G bikes
    Last Post: 05-07-2017, 03:08 PM
  2. 97 650ST Funduro
    By 161612 in forum Thumpers - F & G bikes
    Last Post: 08-28-2011, 04:04 AM
  3. Opinions on the Funduro?
    By georgej in forum Thumpers - F & G bikes
    Last Post: 04-02-2011, 10:36 PM
