Results 1 to 6 of 6
Thread: 97 K1100LT Master cyl locks when brake is applied
    Aug 2009
    Batavia, Illinois
    When front brake is applied master cyl locks and releases only releases when a brake line fitting is cracked
    Blue Buddy
    Buddy,
    That is usually a sign of a failed rubber brake line or the piston in the master cylinder not returning enough to clear the bleedback port. Is this a symptom that has just started or did you just do some work on your bike?
    I'm going to leave your post here for a day or two (or until I know you've seen this), then I'm going to move your post to it's own thread where it will get more attention.
    Aug 2009
    Batavia, Illinois
    Mr. Lee,
    The rubber brake line was replaced with a stainless steel one. At that time the brake fluid was replaced silicon brake fluid.
    When the work was done 3 years ago the brakes worked fine. Two years ago they worked. Since then the bike has been in storage.
    When taken out of storage this July the problem started. No other work was done on the brakes.
    Blue Buddy
    Buddy,
    Did you replace BOTH front brake hoses? The one from the master that goes under the tank to the modulator AND the one that goes from the modulator to the calipers?
    Belton Tx
    Quote Originally Posted by zabeathome View Post
    Mr. Lee,
    Blue Buddy
    If you used silicone DOT 5 fluid it may have damaged the rubber in the components.
    Ron
    91 K75RT ABS
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Agreed: the parts book calls for DOT4, not 5.
  1. 93 K1100LT Front Master Cylinder
    By rcapone28 in forum Flying Brick K-bikes
    Last Post: 09-09-2016, 12:07 AM
  2. Replies: 13
    Last Post: 01-22-2016, 08:06 PM
  3. Front Brake applied but no brake light
    By Ron from BC in forum Oilheads
    Last Post: 04-22-2012, 12:39 AM
  4. K1100Lt front master cylinder
    By jpk1100 in forum Flying Brick K-bikes
    Last Post: 06-24-2009, 12:40 AM
  5. master brake cyl.
    By ENGINEROD in forum Airheads
    Last Post: 04-06-2008, 12:54 AM
