Results 1 to 9 of 9
Thread: auto tire on 07 1200rt/w side car
    redriderbmw
    Mar 2007
    Southern Illinois
    Has any one mounted a car tire on a 07 1200rt with a side car. Looking for a higher millage set up
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I've seen it done on R1200s multiple times. Most often on DMC outfits. A good place to get detailed how to info would be over on ADV Rider's Hacks sub-forum.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    redriderbmw
    Mar 2007
    Southern Illinois
    rt rear tire
    Quote Originally Posted by redriderbmw View Post
    What I meant is a car tire that fits the 1200RT on the stock rim
    Registered User story's Avatar
    Sep 2013
    Redding, Ca.
    I looked into the same thing on my 07 K1200GT. I'm guessing rim size is very similar. There isn't a 17" car tire narrow enough to fit.
    I talked to DMC at the rally in SLC about it. He has not done the R & D for a K1200 rig to put on a car rim with spacers. He may have for your RT though.
    Enjoying life in the beautiful state of Jefferson
    2013 K1600GTL : 2004 VTX1800c : 2007 K1200GT with Hannigen sidecar
    Nov 2011
    Central Ohio
    You might also get some ideas from a recent discussion here: http://www.bmwlt.com/forums/rt-serie...-car-tire.html. The discussion is about RTW rears, but I suspect the Hexhead rim would need a similar spacer to provide swing arm clearance.
    Results are claimed to be good, but I still have doubts about the effect of the offset on final drive bearing longevity.
    Larry
    2006 R1200RT
    Apr 2006
    Nibley, UT USA
    Have never seen one for the stock rim, but check with Claude at FreedomSidecars.com (http://freedomsidecars.com/parts/wheels.pdf). He machines an adapter that allows use of a car wheel on the rear.
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S PD 1993 R100GS 2004 K1200GT w/Hannigan S/C 2010 K1300GT
    Jan 2005
    Roanoke, VA
    I have one on my R1150RT and a friend has one on his K1200LT. We both use an Achilles 175/55-17 that can be bought at Tire-Easy.com, on ebay or from Amazon. About $65. This is the only tire that we have found that fits. I do not need any spacers, the K12 had to add 3 additional 2mm spacers from the K bike. I am on my 3rd one and got 11,500 miles on each of the two. In addition to the longer waer you have additional traction both cornering and braking.
    redriderbmw
    Mar 2007
    Southern Illinois
    rt rear tire
    I bought and mounted a Achillies 175/55-17 car tire on my 07 1200 RT stock rear drive rim. Fits bike very well. Tire rides great. No side wall rubbing. A Hannigan side car is mounted to the bike. I fully expect a lot more service from this set up than having to replace the stock rear tire after 3000 miles and the $57 shipped to house price is the bonus. After 500 miles I can say I am Satisfied, fitment to bike was very good and I will be very happy if I get a possible 11500 miles to replacement. My initial testing was done with passenger and our usual load for a rally camping trip. Thank YOU and a big shout out for positive info I received. More data will come.
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    Not sure if the RT rear is the same size as my GSA rear, but I've been running the Achilles 175/55-17 on my OEM spoked rim this year. Still plenty of tread after 8500 miles. My only downside is that the larger contact area makes the rig easier to hydroplane in heavy rain, but I'm aware of the issue and take appropriate measures in bad weather.
    BTW: I figured the appropriate inflation by riding thru a puddle and examining the wet tread mark on dry pavement. At 36psi the edges of the tread pattern weren't touching, so I dropped the pressure till I saw the full footprint. For my sidecar rig, that was at 30psi.
    Pete and Tulliver
    '18 R1200GSA and '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan sidecar for rides with Glenlivet
    '15 Honda CRF250L for exploring places I'm afraid to take the big GSA!
    http://travelswithbarley.com/
  1. 1200RT Side Bag Damage Fix?
    By tgf429 in forum Hexheads/Camheads
    Last Post: 07-15-2012, 11:37 PM
  2. 1200RT Front Tire Question
    By rderflin in forum Hexheads/Camheads
    Last Post: 05-25-2008, 01:22 AM
  3. Help! 1200RT fell off side stand
    By MrBee in forum Campfire
    Last Post: 05-14-2007, 05:11 PM
