Results 1 to 15 of 15
Thread: R1200RT engine failure
    Art-Vt & Costa Rica
    Jun 2015
    Chester, Vt and Ciudad Colon, Costa Rica
    Last week my 2006 R1200RT suffered total engine failure while cruising at 73 mph on Rt91 in central Vermont
    It was the first ride of the season after an oil change.
    Shop is telling me that this type of cylinder failure is a known issue but I'm not finding any such info online
    Bike has 20000 miles on it
    1974 BMW R90/6 in Ciudad Colon, Costa Rica
    2006 R1200RT, 1996 K100RT, 2012 G650GS in Chester, VT
    Sep 2015
    Rochester NY
    Not a known issue that I have ever heard of.
    Please define "total engine failure" - what component(s) of the engine have failed?
    Quote Originally Posted by r2frame View Post
    "First ride after oil change" and "total engine failure" might possibly be related. Was "cylinder failure is a known issue" uttered by the same shop that did the oil change?
    Lee A. Dickinson - Danielsville, GA USA
    MOA 80364 | RA 29650 | ABC 3480 | IBA 8914
    1976 R75/6 - 1992 R100RS - 1993 K1100RS - 2013 R1200GS
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Calgary AB
    Check out the FPC or Fuel Pump threads. There is one recall issue and other fuel failures that do happen to some bikes due to corrosion. Also a bypass cable can be used to get moving again until parts arrive. Often this failure results in a tow. Mine failed on an expressway at 120 Kph... pretty much as yours did.
    Edit: Assuming the bike 'just stopped running'.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    "Total engine failure" is a very vague phrase.
    Did the engine explode into a million pieces, a rod come through the side, many nasty noises and lots of smoke and oil everywhere?
    Or, did it just stop running ... with none of the above?
    Some of the early 1200 bikes had cylinder wall failure with the Nikasil surface fracturing. I think this was mostly the early R1200GS bikes but am not positive it was restricted to GS engines.
    So what really failed - or doesn't the OP or dealer know?
    Apr 2016
    Seattle
    Quote Originally Posted by beemerphile View Post
    You may have nailed the actual cause there.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    He mentioned the right cylinder. There were right cylinder failures (piston seizing, I think) in the very early years of the R1200. I haven't head of that issue for ten years.
    Anton Largiader 72724
    Tech articles
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    May 2007
    So. Cal.
    I can hardly get past your bike has 20K miles and is 11 years old. Is that right?
    __________________
    Nancy
    2013 R12RT, 2012 Yami FZ6R, 07 F650GS (Sold), 09 R12RT (Sold),
    IBA# 529
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by beemergirl View Post
    That was my first reaction too. Could riding too little be the cause?
    Apr 2016
    Seattle
    Too little riding is probably not the cause.
    I just wonder if the same people who are telling you the engine is known for doing this, are the same ones who drained the oil...and may have caused the problem. I wouldn't put it past them to try covering up that the drain plug or filter wasn't tightened enough and the oil drained out as you rode.
    Chris
    John 14:6
    Quote Originally Posted by daboo View Post
    Chris
    Generally you notice that sort of thing since the rear tire isn't known for sticking well when covered in oil (DAMHIK.. I just do..)
    We need more info from the OP before we can make informed interwebz guesses on the cause.
    Calgary AB
    Yep.
    Ken Dittrick
    May 2016
    Northfield, Ohio
    We need more info from the OP before we can make informed interwebz guesses on the cause.[/QUOTE]
    Oh come on now. It is more fun to speculate what happened and come up with a solution based on the speculation. Who needs facts !!!!
    Roger L
    Mansfield,MA
    It doesn't appear the OP has been back since he edited his post on the 8th
    Mod Squad
    2009 F800GS 1994 TW200
  1. 2005 R1200gs engine output seal failure
    By espressoforyou in forum Hexheads/Camheads
    Last Post: 12-05-2017, 12:39 AM
  2. Rainy engine failure 2000 R1100RT
    By JamesInCA in forum Oilheads
    Last Post: 12-22-2013, 08:16 PM
  3. 06 R1200RT rear failure at 80K
    By blkb1rd in forum Hexheads/Camheads
    Last Post: 12-03-2013, 04:55 PM
  4. '02 1150RT engine output shaft/clutch hub failure
    By OfficerImpersonator in forum Oilheads
    Last Post: 05-10-2008, 06:57 AM
  5. Brake Failure R1200RT
    By dlnoss in forum Hexheads/Camheads
    Last Post: 12-10-2007, 06:31 AM
