Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Added Lighting - Clearwater or Denali
    Cycl2day Cycl2day's Avatar
    Mar 2009
    The Berkshires
    Lightbulb Added Lighting - Clearwater or Denali
    Looking for increased lighting for my 2013 GS. Most importantly, while I know being seen is critical, I am interested in these light more to illuminate the road better so I can see more at night. I once used Denali D2's and did not think they were very good for what I want. I thought the Clearwater Glenda or Darla's might be the thing to do as they are easy to mount and look to be great lights. But then I read about the new Denali D4 2.0 set up. Anyone have experience with these?
    2013 R1200GS (LC)
    previous rides 2007 R1200R & 2002 R1150R
    Tucson, AZ, & Madison, WI
    Clearwater Ericas are programmable and very good a night. Also, make you more visible in daylight.
    Jeff Dean
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    '17 R1200RT, '15 R1200RT, '67 R60/2, '69 R60US, '55 R67/3, '49 R24
    AZ
    No knock against Clearwater lights, they are well made, but they are just way too expensive for me. There are many alternatives at 1/4 the price. As far as dimming goes, I never dim my lights, I simply installed lights that are the brightness I want at all times. YMMV of course.
    MOA #107139
    RA #28511
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I have/had five sets on Denali lites and a set of Clearwater Darlas. Both companies make good stuff. I do think the on/off button on the Denalis is a bit cheap, but bang for the buck goes to Denali. The Darlas are much brighter in day light, but not enough to make a difference in conspicuity.
    Kevin Huddy
    Tm Pterodactyl's MT Outpost
    2017 R1200GSA & 2013 FJR
    Apr 2016
    Seattle
    Clearwater lights are good, but pricey. I have the Darla on my F800GT, but only because the previous owner bought them. The bracket on one side and the light on the other side, had the paint flake off resulting in corrosion to the underlying metal. And no, there were only less than 2000 miles on the bike when I bought it, so it wasn't like they had seen a lot of use. To their credit, Clearwater replaced both the bracket and light...but only after pressing the issue. For the cost of Clearwater lights, there should've been no issue IMHO.
    I'd look at ADVMonster lights. They are extremely popular on the ADVRider forum. I've used their Model 30 lights on two previous bikes with no issue. High quality, lots of light...and low price...$40. Customer service is great too. If I was to replace my Clearwater Darlas, I'd probably buy the Model 55.
    Light Performance
    Beam (degrees): Combispot - 7 degree primary beam provides maximum distance while the spill created by the custom reflector provides the width of a flood light. This is a do it all light.
    Light output (lumens): 3000
    Color Temperature (kelvin): 5000
    Usable Light (feet/meters): 1500/457, Spot that deer, dog, animal/obstacle long before you need to stop.
    I did a comparison on my last bike with another owner who had the Denali lights (previous versions). It was like night and day. I could see no justification for the additional cost of the Denali lights, especially when they were clearly less bright.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    Quote Originally Posted by azgman View Post
    If they are dimmable, they can be the brightness you want on low beam and brighter when you're using the high beam...
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
    Registered User wkuwiz's Avatar
    May 2014
    NW arkansas
    Quote Originally Posted by daboo View Post
    Chris
    +1
    I have clearwater Darla's on my 14 RT which are great and a set of glenda's on my F650 Dakar. Both are solid but have had great luck with a pair of the Model 30's mentioned above on my "01 RT. Brightness in the daytime is what I seek (I try to avoid night riding at all costs). Try a pair. They are a fraction of the price and perform well.
    AZ
    Quote Originally Posted by alegerlotz View Post
    I use high beam 0.01% of the time.
    MOA #107139
    RA #28511
    Registered User gsinnc's Avatar
    Charlotte, NC
    I have run Clearwaters I've run Denalis and I've run Motolights all are great my two cents is if you can afford the Clearwaters I would go with the Clearwaters Denali's are a close second and work well. both are bright for daytime conspicuously and there is nothing better than the yellow amber lenses in the Clearwaters for daytime. The Denalis are now available with amber lens. For lighting up the night you would need to move up to brighter lights in either line up.
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2012 R1200GSA Magma Red!
    2016 R1200RT- Platinum Bronze
    I use high beam 99% of the time and don't ride at night if I can avoid it. 72 yr old eyes!!
    My 77-year-old eyes work fine at night with my Clearwater Ericas shining the way.
    Jeff Dean
    Sep 2016
    Louisville KY
    2016 R1200RT lights
    Quote Originally Posted by bmwdean View Post
    Same here partner. I have 74 year old eyes that need all the help they can get at night. Clearwater Ericas on my 2016 R1200RTW and brighter replacement bulbs for low & high beam as well as a Clearwater billy led auxiliary tail light. I also have a Triumph ThruxtonR that I have the Denali D2's on. No comparison between the D2's and the Ericas for night riding on backroads.
    If the sun's up (cloudless or cloudy) my LED hibeam is on with Clearwater Darla at 100%...
    JWMcDonald
    2016 R1200RS (current)
    2003 R1150RS (prior) / 1978 R80/7 (prior) / 1966 R69S (prior) / 1972 R75/5 (prior)
    Windsor, California
    My R1200RTW accessories:
    Jeff Dean
    Apr 2016
    Seattle
    Quote Originally Posted by JWMcDonald View Post
    If I did what you are suggesting, I'd have 13,400 lumens shining in everyone's eyes. That's blinding.
    I had another rider pass me on the other side of my lane without any warning at all. I decided to turn on my highbeams to just show a little irritation at him. (I know, not a very forgiving attitude...) He switched sides of the lane to get out of the light. I switched to stay behind him. He finally switched into the lane next to ours to escape.
    Point is, you have no idea how blinding that is. It isn't just being seen. It might also keep another driver from seeing a pedestrian or whatever in the seconds after you pass. It's dangerous.
    Chris
    John 14:6
  1. 02 K1200LT Denali DM1 Microlites
    By Old Rookie in forum Flying Brick K-bikes
    Last Post: 02-02-2017, 08:55 PM
  2. Denali air horn on R1200RS - Who's done this?
    By romany in forum Wetheads
    Last Post: 01-24-2017, 02:05 PM
  3. Denali D2 LEDs on an RT
    By HFD190 in forum Oilheads
    Last Post: 05-02-2012, 11:32 PM
  4. Denali d2 lights
    By booger man in forum Wedge K-bikes
    Last Post: 01-25-2012, 01:57 AM
