Results 1 to 11 of 11
Thread: Cyclops H7 Installation 09 RT
    Aug 2006
    Scranton, Pa.
    Hi folks,
    Yes, the slow learner is back. It seems the best way to install the new bulb is to remove the entire headlight assembly. Can someone send pictures to show me how this is done? I have had the 1100Rt's apart more times than I would like to remember but my present bike is an 09 so it is all new to me. Many thanks to the brotherhood.
    3hawks
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    HERE is the thread I used.
    It really is a pretty simple procedure. You can ignore the windscreen arm removal steps.
    I removed mine as the sockets were brittle and crumbling. I ordered new H7 ceramic sockets and replaced all three of mine.
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT, '70 R75/5, '73 R75/5, '11 Ural Patrol
    N0PGH
    Iron Butt Assoc. #47865
    Just another rider 61242's Avatar
    Wisconsin
    Quote Originally Posted by brisco View Post
    HERE
    Where did you get the ceramic sockets?
    Oct 2010
    De Soto, KS
    Quote Originally Posted by 61242 View Post
    Amazon.
    Here is one link, although back when purchased them, I bought them separately.
    N0PGH
    Wisconsin
    Amazon.
    Thanks! And trying to not to hijack the thread, but it looks like I need to remove the headlight assembly on my '09 RT also. During my recent bulb replacement ordeal I managed to drop one bulb down into the assembly. While trying to refit the connectors onto the bulbs they crumbled/self-destructed (likely in shame).
    Headlight assembly removal is retaively easy! Stuffing around with my light assembly (one/off/on/off/on) this week has me doing it in minutes. I an old retired mechanic though with a mirad of sockets and fittings. !2 minutes flat!
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by leon.schmeider View Post
    12 minutes flat!
    Is that 12 minutes off or off/back on? One is impressive and the other unbelievable.
    Quote Originally Posted by mikegalbicka View Post
    Am away at Gloucerter NSW with friends but had it off and on so many times during the week that from memory it goes like this!!!
    An Allen head for the windscreen 6 screws, 2 easy to remove circlips for screen alloy supports, star hex screw bits across the top of dash are, side 2 each fairing under front, (mine with a horn hanging off each side) a rear fairing screw and lower dash fork side screw. Dash cover 4 screws and then the bigger 4 star hex screws that allow for the front fairing and headlight assembly to come off, noting hand down inside to unplug aerial and the main headlight assembly plug. Last and tricky earth strap to the fairing.
    I was scared at first but youtube and this forum assisted. With the right fiddly tools on hand a very easy job! And that was 12 mins "eachway, Jose`"
    Lol Aussie Bob!
    Registered User froggy's Avatar
    Feb 2010
    Ballwin.MO
    Headlight Assembly
    Does the 2013 RT HLight assembly come off the same way as the 09 ?
    We drove all this way for a DEAD END ! My son!!!
    02 Silver RT1150 My 1st BMW Bike ...Totaled 2/23/16
    13 Black R1200RT 90th Annv
    Craig
    Quote Originally Posted by froggy View Post
    I could not say, however I expect it would be close, have a star head screw set, small ratchet and adapters to carry star sockets where needed and go for it no fear!' oh don't forget YouTube!
    Jul 2013
    Solvang, CA
    never had the opportunity to take a 09RT headlight assy off, but the 13RT is pretty easy....took me about 30 mint to remove, install the the three Cyclops LED lights and replace the assy....i have had lots of practice though in replacing the standard head light bulbs....LOL
    ~wyman~
  1. Cyclops H7 Headlight bulb installation 2009 R1200RT
    By will3hawks in forum Hexheads/Camheads
    Last Post: 07-30-2017, 02:18 AM
  2. Cyclops LED Bulb Replacement
    By BC1100S in forum Oilheads
    Last Post: 05-02-2017, 08:12 PM
  3. Replies: 5
    Last Post: 10-16-2016, 04:35 PM
  4. tankbag installation
    By kgadley01 in forum Gear
    Last Post: 06-04-2008, 06:29 PM
  5. MotorCycleCruise installation on GS
    By slip in forum Oilheads
    Last Post: 05-14-2006, 03:21 PM
