Results 1 to 3 of 3
Thread: Possible warped rotor
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    I have this cross posted on the K16 forum but for a wider audience I'd like to ask here.
    About 10k miles ago I noticed an ever so slight pulse under light breaking that would end in a sort of judder the last few feet of a stop. Heavy breaking this was less noticable.
    I thought at 15k maybe the front pads we're going off, they were about 60 percent worn so I replaced the pads.
    This helped, but the problem quickly returned and is getting worse, mainly the last few feet of a stop there is a clear judder almost a grinding feeling.
    Rotors are smooth and it's not the rear since stops with just the rear brake are smooth.
    My feeling is a slightly bent rotor, just looking for opinions.
    I did lift the front wheel and there is no binding, I do not however have a way to measure run out.
    Sent from my Pixel using Tapatalk
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    Dear BMARC,
    The only way to verify if your rotors are warped is with the use of a dial gauge to measure run out.
    The good news is that you can buy a dial gauge kit for under $50 US.
    Before you buy one and the holder, you will need to check if you can use a magnetic holder to secure the gauge to the forks or if you are going to need another type of holder.
    Another thing I just thought of, have you cleaned the surface of your rotors before installing the new pads and are those pads BMW OE.
    Please email me here if you need more information or on the K1600 forum, I have the same user name there too, frenchnew.
    Robert
    2016 K1600GT Cosmic Blue , ABS, ASC, ESAII, TPMS & Alarm, Radio, Sat, GPS Nav V
    Skene IQ150-TS front and IQ 160-TS rear
    Dec 2014
    Orange County, NY
    Hi Thanks. The pads are ebc and I didn't clean the rotors when I swapped pads. I should have I know I should have but didn't have any scotch Brite pads.
  1. 2007 R1200R - Warped brake rotors/discs
    By FredRydr in forum Hexheads/Camheads
    Last Post: 10-01-2008, 12:26 PM
  2. Warped brake discs -- common problem?
    By Ride2wheels in forum Oilheads
    Last Post: 06-18-2008, 01:21 PM
  3. Not warped discs but pulsating brakes!
    By bransan in forum Oilheads
    Last Post: 10-29-2007, 11:48 PM
  4. warped sense of ha ha
    By 177195 in forum Campfire
    Last Post: 12-29-2006, 10:59 PM
  5. warped gs frontend
    By rkgsz3 in forum Oilheads
    Last Post: 04-17-2006, 08:18 PM
