ncpbmw1953
Member
....but was able to right it using the squat and back into the bike method. No damage because the bike had cylinder head and bag crash bars.
I know I'm setting myself up for eating my own words but am determined to never drop this bike, at least not for any kind of the common issues riders have that end up leading to a drop. But I know all's it takes is a momentary lapse of attention in applying all the things we know about and have practiced in low speed handling on a top heavy bike. Doesn't really feel top heavy to me now but it did coming off F800GT last year.
Imagine this 'what if'. For the cost of full crash bars, that is for $750 you pay up front on Day 1 of ownership, someone signs a contract to give you one million $$ if you never drop your RT for every 100K miles you ride. Would you pay $750 for a shot at $1,000,000? I try to ride like this offer was real! I'm talking about low speed drops, not crashes per se.
You can learn a lot from other's mishaps. I never ever start to tip the bike's weight on to the side stand unless I've visually verified it's in it's fully extended position first and I learned that simple OCD trick from reading a couple guys' tales of woe from not incorporating this practice into their own routines. One was of a GW rider I think it was who went on a really long tour only to arrive back home in the garage, and commence to get off the bike without putting the side stand down at all! Something as simple as that rule, 'ALWAYS visually verify' eliminates this possibility.
Here's my bonehead mental error that led to my one drop on my F800GT and subsequent back injury from the other bonehead thing I did:
I have a 40' long gentle slope down to my garage. I have to turn 90 degrees when I get to the back of the garage in order to park perpendicular to the normal parking orientation. I had a habit of turning off the bike about 20' out of the garage and I would coast in neutral until it was time to turn 90 degrees at which point the steering is turned at hard lock barely moving. I always apply only the rear brake at the point I'm starting to turn. Well, this day was my first ride out w/ some new TCX boots that I bought for their tale toe box. I believe for all of those entrances done this way I never pulled the clutch in because I would be in neutral for the coast. On drop day what happened was I accidentally, I'm sure because of the new boots, put the bike in 1st gear as I must have been pre-loading the shifter by accident. This happened halfway thru my 90 degree turn and down she went in the blink of an eye. So, since then, the clutch is always pulled whenever I'm still moving in neutral. This eliminates the risk of an inadvertent shift. I hurt my back quite badly for the very first time in my then 62y when I tried to do the squat and back into the bike method. The bike was so flat on the ground that as I pushed w/ my legs I could not get it to pivot on the tire--I was just pushing the tire into the garage floor sideways. I started lifting with my arms at that point, it wouldn't budge, and then a 'pop!' and down I went in severe pain. It's bothering me right this second and it happened over 2y ago now. But at least now sciatic pain or weakness.
Other things I do is try to be disciplined to only park where drop risk factors are absent. It's hard to do this sometimes especially when with other riders who all decide to park in a certain place. I'll look and ride to wherever I need to to have a good entry and future exit even if I have to walk a little further. These sorts of commitments as well as standard good low speed handling tactics can all but eliminate drop risk.
