Results 1 to 10 of 10
Thread: 12,000 RTW service.
    12,000 RTW service.
    All,
    Very soon I will be performing the service on my bike. It's a 2014 that I had bought a hand full of months ago. I think I'm handy enough to do it and I have most of the tools needed. I will be getting the DVD manual and I need larger torx tips. Does anyone know the largest size torx that I will need? I have up to a T45. Thanks for any info!
    Sent from my SM-G920V using Tapatalk
    Mansfield,MA
    Welcome to the forum!
    On the Torx, there has been some discussion on sizes.....don't know the "largest" you may need. I buy them by the set.
    You may be interested in this- https://forums.bmwmoa.org/showthread...Mods-and-DIY-s
    That thread has a lot of good info on numerous maintenance topics.
    Good luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Registered Schmoozer irish's Avatar
    Oct 2009
    Madison, WI
    I just did the 12,000 mile service on my wethead GS. I have a decent tool collection from doing service on my oilhead RT but I needed two additional things: A 10mm hex bit socket (I think for the engine oil drain plug) and an ignition coil puller (the oilhead one is not compatible and the lame wethead tool kit doesn't include one). I was able to make due without the coil tool by using a screwdriver to leverage the coil out but I don't want to do that again. I have a coil tool on order now. I did buy the hex bit socket so I can torque the bolt down properly. I'm not sure what the largest Torx bit is that you need. My set goes to T50, I think T45 is the largest you need but wouldn't swear to it. Maintenance was easy, much faster than the oilhead.
    14 R1200GS, 02 R1150RT (retired)
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Since I have not had a BMW boxer since the 80s I found the JVB Productions Service Video DVD very helpful.
    http://jimvonbaden.com/Wethead.html
    In the link above click on "Link To Tools List" for a list of tools and sizes needed.
    The BMW DVD repair manual is also handy to have.
    Three places to buy a coil puller.
    http://stores.promachdualtool.com/new/
    http://www.beemerboneyard.com/83300401700.html
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Lee
    2016 R1200RS
    MOA # 30878
    kellenbenz kellenbenz's Avatar
    Dec 2012
    Tyler, Texas
    You will also need a deep thin wall 14mm socket for the spark plugs and metric feeler gauges to check the valves.
    The only thing that requires a T50 torx is the rear wheel.
    The air cleaner is the worst part....but not that bad after the first time.
    I agree that a coil puller is very necessary.
    Ron
    IBA 45658 MOA167437
    679,111 miles on touring motorcycles
    Total BMW miles 440,728
    Oct 2009
    Madison, WI
    Regarding the air filter, my Haynes manual said to take off all kinds of body work but then mentioned that on the GS it's possible to replace it with only the body panel on top of the tank removed. I was worried about over-flexing fragile body panels but after completely removing the filter cover fasteners I was able to move the cover forward and out with minimal bending of panels. I will definitely continue with this method. Would have been a PITA to remove all the panels, this method took maybe ten minutes.
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Regarding the coil puller, you really don't need one if you're handy with a flathead screw driver and some patience the first time around. You then lube the rubber bits and the inside of the coil with dielectric grease and then can now pull them out without a tool the second time around. The black cover cap keeps the coils from coming out anyway. YMMV
    MOA # 108516
    Current ride 2017 R1200RT White
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA
    Mar 2011
    socal
    To remove the coils, buy a Marc Parns coil removal tool, defiantly a better mouse trap
    May 2003
    SW Iowa
    Quote Originally Posted by kellenbenz View Post
    The T50 is also needed to remove the valve cover.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2015
    York, PA
    12k service on my GSA
    Completing the 12K full service on my GSA...
    At first glance, the plugs looked great (nice tan color) but I replaced them anyway following the recommended service schedule.
    Looking at them closer with 2.75 cheater glasses, the electrodes are more eroded than I thought and expected. The electrodes are more "ovalish" or "rectangularish" than round.
    It's not like they were in bad shape and probably would have been ok for another 12k but I'm glad I changed them. I'm sure the gap changed due to the erosion.
    I've been following my own 4k oil change (engine & fd) interval (1 extra oil change; no big deal) but now plan to go with the standard 6k interval. The oil and fd drain plugs were perfect; no metal on the magnets.
    2015 R1200GSA
  1. BMW service in WV?
    By chord97 in forum Regional South
    Last Post: 08-06-2011, 04:01 PM
  2. Do I need a service or not? 09 GS
    By beeryboats in forum Hexheads/Camheads
    Last Post: 06-08-2010, 05:29 PM
  3. BMW Service (Hello, anyone in There?)
    By roch2nite1 in forum Regional Northeast
    Last Post: 06-07-2010, 01:27 PM
  4. I could use some help with my first 12K service
    By kukuramd in forum Oilheads
    Last Post: 10-29-2008, 07:19 PM
  5. How much $$ for 36k service?
    By nevada72 in forum Oilheads
    Last Post: 09-04-2008, 08:17 PM
