Results 1 to 15 of 20
Thread: Rear sprocket F800gsa 2017
    Question Rear sprocket F800gsa 2017
    have new 2017 f 800 gsa, frt sprocket is 16 and rear is 42. I ride cross country and and RPM is 4500 at 75 mph would like to drop that down and run at 80 mph at around 4000 or just slightly less. I am think a 44 tooth rear gear would get me closer to what I need. Any help out there or suggestions, my first time messing with rear sprockets and charts are helpful but experience best teacher. thanks, TJM 112299
    Quote Originally Posted by TJM View Post
    have new 2017 f 800 gsa, frt sprocket is 15 and rear is 47 i think? I ride cross country and and RPM is 4500 at 75 mph would like to drop that down and run at 80 mph at around 4000 or just slightly less. I am think a 44 tooth rear gear would get me closer to what I need. Any help out there or suggestions, my first time messing with rear sprockets and charts are helpful but experience best teacher. thanks, TJM 112299
    Why? This appears to me to be putting the top gear into engine-lugging territory. What was your previous bike?
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I think 4500 RPM is right in the sweet spot for cruising with the F800 motor.
    Kevin Huddy
    Mansfield,MA
    It's not a big expense and just work to try it........With my '09 F800GS, I'm thinking that a 3T change would make a "roll-on" throttle pass a gear dropper. A hard pass would require dropping 2 gears.
    Let us know how you make out.
    Mod Squad
    2009 F800GS 1994 TW200
    Was 2010 r1200 GS rode 4 corners in 2014; idea with 6th gear and 4500rpm was on highway at speed , reduce vibration and ease up on engine rpm with loosing to much torque. Can use gear box to shift at low end but need a smoother top end ??? thoughts.
    Will let you know how it works out, going to NC in August and will give the bike a good run.
    Riding for the SON
    Pasco Wa.
    Get the F650gs set up which is 17 42
    gig harborr ,wa
    Yes ,you are right.
    gig harborr ,wa
    The boxer engine and the F engine have two total different characteristic. The F needs to rev, it does not like to lug. When you change sprockets I would try it out on a until 500 mile run first. Hopefully this bike is only for highway use? Let us know how it works out.
    Riding for the SON
    Pasco Wa.
    Quote Originally Posted by EUGENE View Post
    Yes ,you are right.
    Mine becomes very bussey at 5000 rpm--80 mph.
    only plan for highway and trip to alaska, some off road and gravel but very little. Thanks for your thoughts and everyone who help me think this through.
    Quote Originally Posted by ROYBARNES View Post
    How did you handle it or are you living with it?? not sure a 650 set up is right?? delaer suggested going to a rear sprocket of 44t rather than 47t and leave frt alone??
    Mansfield,MA
    In the old days of dirt bikes, we used to figure 1 tooth in the front was about a shade over 3 in the rear.
    Mod Squad
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    I want to also note that I've read to not make both sprockets even #'s....
    just talked to my dealer who looked up my vin and confirmed my ratio. my 2017 F800 GSA has a 16t frt. and 42t rear sprocket. now need to calculate engine RPM at 80 MPH. Goal for me is to reduce engine RPM to 4000 or less at 80 mph.
  1. Weighing in on the F800GSA Versus the R1200GS
    By romany in forum Motorrad
    Last Post: 07-19-2017, 02:35 AM
  2. F650cs rear sprocket - issues again
    By wisconsinkris in forum Thumpers - F & G bikes
    Last Post: 04-30-2012, 01:25 PM
  3. 2005 f650CS - loose rear sprocket?
    Last Post: 02-05-2012, 03:40 AM
  4. Noise in rear sprocket area
    By Jeffries in forum Thumpers - F & G bikes
    Last Post: 08-27-2009, 11:29 PM
