Results 1 to 15 of 20
Thread: Changing tires on a bike with TPMS
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    I'll be due a new set of tires on my 2016 GS in the next month or two. My garage is the local "tire change community" for a few of my friends, but I have yet to change tires on a bike with the Tire Pressure Monitor Sensor. Any precautions I should follow or other advice to prevent damage to these ungodly-expensive devices?
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW
    Registered User gloucesterman's Avatar
    Oct 2016
    Rockport, Ma.
    Howdy,
    There should be a sticker on the rim identifying the location of the sending unit. Once you know where it is avoid hitting it with a tire iron or a tire bead.
    Later,
    Norm
    Fastman Fastman's Avatar
    Webster Groves, MO
    I've changed the tires on both my and a friend's '16 GSAs. Just stay away from/be careful around the valve stem as that's where the TPMS sensor is located.
    Sent from my iPad using Tapatalk Pro
    Fastman
    '86 R65, '96 R1100RS, '04 K1200RS, '13 K1300S 30th Anniversary - SOLD
    '16 R1200GSA
    The most notable thing you can leave for posterity is your name...signed Anonymous
    Start the demount and mount procedures AT the TPMS sensor
    Lee A. Dickinson - Danielsville, GA USA
    MOA 80364 | RA 29650 | ABC 3480 | IBA 8914
    1976 R75/6 - 1992 R100RS - 1993 K1100RS - 2013 R1200GS
    Mar 2010
    Wills Point, TX
    I avoid going near the TPMS sensor. It's located at the valve stem.
    Jay
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Go to the NoMar tire changer site. Look at their FAQ; it addresses this issue. They say to view their video on changing a tire on a F650GS (single cylinder) and to follow the same procedure with TPMS.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Thanks for all the helpful replies! Ironically I just ordered some supplies from the No Mar site. I'll go back and check out that video as well.
    2016 R1200GSW
    Registered User cwroady's Avatar
    Dec 2013
    OC, SoCal
    Here is the cheat sheet I made for myself incorporating input from someone on one of the forums after I made a similar request to yours. Has worked well for me on several sets of tires now.
    * TPM Tips:
    * The sending unit is where the filler valve is. Look carefully at the r/s of the wheel and you'll see a label marking the spot. They are very narrow and mounted in the center of the wheel which leaves lots of room for your tools. I always break the bead away from the sending unit and use care when inserting my tire removal tool end so it only goes in far enough to grab the bead. Otherwise its far enough out of the way not to be a concern.
    *I usually start and end mounting next to the TPM sender. That way you can get the opposite side of the bead fully in the drop zone. After I get the tire iron or demounting bar inserted, I work towards the TPM sender, i.e. the first bit of the bead that comes off is over the sender. When mounting I start next to the sender and then work away from it so that the last part of the bead to be mounted (the difficult part) is the last thing to go on.
    Another tip is to check the torque on the sender bolt. They have been known to come loose.
    *That torque is low, I believe 9Nm. If you have touched the unit with the tire bead while removing the tire, the sending unit will be out of alignment, not straight in the rim. I just gently grab it and give a wiggle. If it move even a little I get the torque wrench out. If there are any doubts, some soap bubbles on the stem when back together will let you know if you have to go back in. The rubber seals are available in a kit that also has the mounting hardware so it is $19. I mark the tire and as mentioned don't brake the bead over the unit, just near and the rest of the tire.
    Chris - 2015 BMW RT / 1972 BMW R60/5 / 1973 BMW R75/5 / SCBMWRC
    There ain't nothing like a friend who can tell you're just pissin' in the wind.
    Neil Young
    It sounds like you have changed a lot of tires. I doubt you will have any problems, however;
    My 2014 RT has been somewhat of a nightmare to balance. BMW made no provision in the wheel design to counter balance the TPMS.
    I can get them to balance but I'm using more weight than I ever have while using good tires.
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by dirtfarmer View Post
    Find the heavy spot on the tire if you feel you are using a lot of weight, rotate the tire, they aren't balanced. If tires where balanced you'd just balance the rim and never have to do that again. I recently put on a set of Metzler Roadtec 01 they have a dot for the heavy spot, I used very little weight on the rear. Keep tools and the tire away from the TPMS. I usually have the valve at about 4 o'clock and start my tire tool about 8 o'clock, rotate my tool clockwise. Before I start the tool I walk the tire back and put the "yellow thing" to the left of the valve before the TPMS. The "yellow thing" is https://www.nomartirechanger.com/Yel...ellowthing.htm it's great.
    Jay
    Registered User lirider's Avatar
    Oct 2015
    LI, NY
    Quote Originally Posted by strataj View Post
    Jay
    I guess it depends on the dot you are referring to but I thought the yellow dot indicated the light balance point on a tire. You would then align that with the heavy point on the wheel, which usually corresponds to the valve stem/TPMS sender location. If it's a red dot, then it indicates the high point on the tire. Either way, it gets aligned with the valve stem or the wheel low point if it is so marked.
    The "yellow thing" does look like a nifty little helper ... always a challenge to not have the bead walk around the wheel when you're trying to seat it.
    2016 BMW R1200RT
    1996 Honda VF750C Magna
    1983 Honda CB550 Nighthawk
    Jul 2007
    Wheels with a TPMS sensor installed are excellent candidates for permanetly balancing the wheels without a tire mounted.
    Kevin Huddy
    If you decide to have a MC dealer change your tire, make sure they know how! I took my rear wheel to a local non BMW franchise and they ended up buying me a new wheel!
    Northern Front Range, CO
    1) Balance the wheels after removing old tire, but before mounting new one.
    2)Mark the heavy and light spots on inside of rim (i used a white paint stick marker). On my rear wheel, the TPMS/valve was quite clearly the heavy spot. On the front, the heavy spot was 120 degs off from the TPMS/valve.
    3) Determine if the red dot on your tire marks the heavy or light spot (I asked a volume tire seller about my Pirellis- said that red dot = light spot), as they do seem to vary.
    4) Mount tire accordingly, based on step 3.
    Doing it this way (2nd tire change for my 2016 3B GS), I ended up using FAR fewer weights than the first time I did it (without having balanced a naked wheel). This time I used 1 oz (4 weights) on one wheel, and only 3/4 oz on the other... WELL within the recommended limits.
    Ride Safe, Ride Lots
    Yesterday I attempted to mount a set of Continental Road Attacks on my GSA rims. Unfortunately, with that beefy "lip" on the spoked wheels, my old Coats 200 Cycler manual tire machine from the 1970s was not up to the job (it could not grab this type of rim properly). I did manage to get the front tire on, but the back tire will be impossible with my current tire changing rig. For those of you that have done tire changes on these monster GS wheels, what are you using? I'm looking at the mid-priced No-Mar on their website, so I was considering that. Tomorrow I'll take it to the local non-BMW shop, and I'll tell them to be mindful of the tire pressure sensor on the wheel. First time I've had to have someone else change a tire in a long time!
    2016 R1200GSW
  1. Changing tires in Yukon
    By jalanrowland in forum Off the Beaten Path
    Last Post: 09-11-2017, 01:22 AM
  2. Changing Tires in Olympia, WA
    By timtyler in forum Regional West
    Last Post: 07-12-2014, 03:44 PM
  3. changing tires
    By Alistair in forum Airheads
    Last Post: 06-13-2011, 09:08 PM
  4. Changing Tires
    By cjcs in forum Wedge K-bikes
    Last Post: 08-17-2010, 10:40 PM
  5. Changing tires by hand
    By keelerb in forum Airheads
    Last Post: 09-15-2008, 09:03 PM
