This bike is about to drive me insane. Bought it in February and put a few hundred miles on it. Needed tires so I took the wheels off and had them mounted. Put them back on and also checked the air filter while I was at it. Put it back together and it wouldn't start. Told it was probably the fuel actuator so I replaced it today. Still wanted to idle rough so I pulled the fuel filter and cleaned it out. Reassembled again and it started right up. I let it idle up to operating temp with no issues. Cut it off and let it cool down. Had an errand to run so I hooked it up to my battery tender (which I do with all mine when they're not being used) also filled up my gas can and brought it back. Added a couple of gallons and when I turned the key my battery was flat? It had blown two fuses also. I did have it still hooked to the tender when I turned the key. Replaced the fuses and hooked it to a regular charger. It's been on the charger for over 3 hours now and still is not taking a charge. What the hell have I done? Thanks for any help I can get.
