Results 1 to 10 of 10
Thread: 2010 R1200RT Front Fork Slider Replacement
    Aug 2016
    Kalamazoo MI
    Hi,
    How difficult is it to change the front fork lower slider on a R1200RT? I looked through the tech library and didn't see any info, so I was curious how big a job this was and if I wanted to take it on. Looks like removal of tires, brakes sensors, fender and maybe an oil seal, but not much else. Anyone done this one?
    Thanks,
    Jerry
    Do you mean replace the slider or the seal?
    The process is about the same, so look up seal replacement.
    Aug 2016
    Kalamazoo MI
    Replace the slider. But since it's out I may replace the seal while I'm there. Thanks for the info. I'll go look that up.
    Jerry
    Oil for front forks.
    I haven't scoured my haynes manual yet for oil change intervals for front forks. So far, mine are not leaking, but wondering if there's an age or estimated mileage interval that one should change fork oil. Any idea what weight oil and volume goes into each fork leg?
    Jun 2009
    Rochester, MN
    Quote Originally Posted by marlen.padberg View Post
    No official BMW recommendation... but some oil is better than no oil, and clean oil is better than dirty oil...
    I have noted: "RepROM, 5th edition, 2/2007 says .45 liter per leg for the K26 0388 model R1200RT. 10 weight oil."
    Jul 2013
    Solvang, CA
    y'all realize this thread is over 2 years old...right...?
    ~wyman~
    Sep 2006
    CENTEX USA
    Quote Originally Posted by wyman.winn View Post
    Not Marlens post
    There is minimal oil in the forks as they do no dampening, just lubrications of sliders.
    If not leaking,I would leave be. I only check or change if someone has a long leaking seal
    Nov 2017
    Collierville, TN
    For some topics (for me this would be technical how-to discussions) it makes to revive older threads rather than have multiple ones on the same topic. Easier to find what you're looking for instead of having to read 5 different threads on the subject.
    The Blue Max 31310's Avatar
    Apr 2008
    Calgary Alberta
    My Clymer manual, page 11-46 states the following, 10W oil (presumably fork oil) for all models as follows:
    GS/GSA 650 ml
    R 460 ml
    RT 450 ml
    S 600 ml
    ST 650 ml
    However, my Haynes manual lists following on page 4-1, 10W telescopic fork oil
    GS/GSA/ST .65 L
    RT .62 L
    S .6 L
    R .46 L
    Note the difference for RT models, not sure what to make of that. Neither manual specifies how often but I recall reading somewhere to change oil annually.
    2007 R1200RT
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by 31310 View Post
    I agree with Steve, there's no reason to change the fork oil on that model since it does not provide damping.
    Lee
    2016 R1200RS
    MOA # 30878
  1. 2010 RT - Front Wheel Bearing Replacement
    By 105258 in forum Hexheads/Camheads
    Last Post: 09-28-2014, 01:14 AM
  2. Finding front fork legs for '07 R1200RT
    By natrab in forum Hexheads/Camheads
    Last Post: 03-04-2014, 04:31 PM
  3. Fork Slider Oil Leak
    By rapz in forum Airheads
    Last Post: 01-31-2013, 05:57 PM
  4. broken fork slider
    By CANADIANSTEVE in forum Airheads
    Last Post: 04-04-2011, 02:35 AM
  5. R1200RT gas tank interfering with front fork!
    By 4stroke in forum Oilheads
    Last Post: 05-13-2007, 04:34 PM
