Results 1 to 6 of 6
Thread: Luggage Rack
    Jan 2016
    Central Illinois
    Luggage Rack
    1994 R1100RS luggage rack drops 2 inches front to back any prefabricated level luggage racks out there. I can get a piece of aluminum and make something. I use wood to level up milk crates which make a inexpensive top box.
    It is very easy to cut spacers from aluminum [my choice] or solid plastic stock using only a hand hack saw...then drill center.
    I did this on my 99 RS, [same rack] and it worked out well.
    Ron Prior {AMA member ,MOA member}
    Milford,Oh
    2002 KLT
    2004 Roadster
    RK Ryder
    London, Ontario
    Find a GIVI plate (used for a GIVI top box) for your bike. That plate would give you a level area above the tail. This can be purchased separately without a top box.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Quote Originally Posted by Paul_F View Post
    If you use just the 'plate'?...you still need to level the 'uprights' . If you buy the whole assembly ? then yes it mounts level.
    IMO leveling the uprights & using just the plate...makes a cleaner setup . Then you have the option of 'strapping' on or 'snapping' on...the Givi trunk.
    Milford,Oh
    2002 KLT
    2004 Roadster
    Jan 2016
    Central Illinois
    Quote Originally Posted by 71243 View Post
    The Givi E183 rack rated a 6 kilogram carrying capacity are they that week or overly cautious?
    What is the original BMW one supposed to carry?
    Quote Originally Posted by 179212 View Post
    Not sure what the OEM rack is rated at but most are around 25# which is 11+kilo...
    The full rack & plate assembly from Givi seems fairly stout IMO. When I used that combo on my 1150 Roadster it held my Givi52 trunk, loaded , with no problem....so?
    LOL...there were times when loaded meant a case of beer plus...
    Milford,Oh
    2002 KLT
    2004 Roadster
  1. Luggage Rack for 86 R80
    By mchaven in forum Airheads
    Last Post: 01-14-2011, 01:52 AM
  2. GS/GSA luggage rack?
    By talmadge_w in forum Hexheads/Camheads
    Last Post: 03-31-2010, 01:44 AM
  3. A flat bed rack for the rear luggage rack
    By alzyck in forum Hexheads/Camheads
    Last Post: 03-22-2010, 03:01 AM
