Results 1 to 11 of 11
Thread: Need a chock!
    Need a chock!
    What sort of wheel chock fits a C650GT- 2016 ? Need to keep it from jumping around the trailer, on the way to Utah next month! I've tried two- neither worked.
    TIA-
    CENTEX USA
    What size tire on those?
    Steve Henson-Mod Team and club tire changer
    Debbie's Servant Lee's Avatar
    SW Iowa
    Baxley and Condor sell scooter chocks that fit 15" wheels.
    http://www.baxleycompanies.com/Scooterchock.html
    http://condor-lift.com/scooter-chock
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    Quote Originally Posted by danpaddles View Post
    TIA-
    Might be good to have a bit more information. Along with the chock, as far as I'm concerned, you still need a 4 point tie down. I have never seen a chock not work, only some working better than others.
    The 2 I use the most- I made out of channel iron and allows me to tie the wheel to the chock.
    Give us some specifics and we will try to help you out
    Gary
    ---you can also look through the similar threads at the bottom of the page.
    Mod Squad
    2009 F800GS 1994 TW200
    will look some more-
    The wheel is small, the brake is large, is the short story. I'll look at some of the suggestions, thanks.
    like that Condor stuff
    Also, like the pitbull chock- https://www.pit-bull.com/wheel-chock-f0017-000
    SW Iowa
    I like how the Baxley pinches and grips the tire when the wheel rolls into it.
    Lee
    2016 R1200RS
    MOA # 30878
    There is extra crap... er stuff, on the front wheel.
    The tires are 120/70 R15. The chocks I have now will hit the brake disc, plus there are other ...things on the bottom of the fork.
    Someone mentioned- how will I strap it. Good point! I was going to work on that after I had the chock in place. I'll look that over later.
    I have a little time now, it has been decided by management that (her) scooter will not need to go to Utah. My GS I already have figured out. But I'll still need to trailer the scooter at some point.
    Will look again at the chocks previously mentioned, I think the answer might be there.
    Feb 2010
    Cape Cod, MA
    Baxley and Condor do sell a scooter chocks.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Central Ohio
    I think the Harbor Freight chock would work.
    I move mine between my lift table and my trailer. Bolted down, it provides two tie down points in front.
    I don't think there would be any interference with the fork or brake discs. Not a great video, but https://www.youtube.com/watch?v=yLEa-uic6lw shows a side view of a bike rolling into the chock.
    $57.99
    Take 20-25% off with a coupon from http://www.hfqpdb.com/. No need to spend big bucks for a seldom used item.
    Spend some of the savings on quality tie down straps. I like the High Roller brand, which has several models with integral soft ties and closed hooks.
    Larry
    2006 R1200RT
    Thanks, I'm over thinking this. Looks like Condor or Baxley or HF would all work. The cradle thing is the way to go for sure. Thanks again.
    See you in Utah!
    -Dan
  1. Harbor Freight Wheel Chock setup?
    By rkildu in forum Gear
    Last Post: 01-30-2012, 04:39 PM
  2. Baxley LA Chock Question
    By JIMK23 in forum Motorrad
    Last Post: 09-24-2010, 12:41 PM
  3. Baxley LA Chock Question
    By JIMK23 in forum Gear
    Last Post: 09-23-2010, 01:46 PM
  4. Wanting to get a wheel chock for my GS
    By Fletch66 in forum Gear
    Last Post: 07-04-2009, 06:35 PM
