Results 1 to 4 of 4
Thread: Wheel Bearing
    Wheel Bearing
    Has anyone else had a problem with premature wear on the rear wheel bearing on a XR?
    Mansfield,MA
    Welcome to the forum!
    I don't know on the XR, seemed premature on my F-800gs.
    Enjoy the forum.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    The rear wheel bearing is not a commonly reported issue. Anything can fail early but this issue is rare.
    You might want to check your drive chain adjustment. If adjusted to spec on the centerstand the chain will be too tight and could lead to premature bearing failure.
    The correct procedure is to adjust while the bike is unloaded and parked on the sidestand.
    2018 R1200RT W - Continent traveler
    2016 S1000XR - Smile Maker
    1976 R90/6 - Just Plain Fun
    XR Wheel Bearing
    I did at 4000 kms, but traded it for a RNineT GS.
  1. Wheel bearing service R90
    By 8ninety8 in forum Airheads
    Last Post: 01-28-2017, 04:05 PM
  2. R65 Wheel Bearing Grease
    By grover1949 in forum Airheads
    Last Post: 10-24-2016, 07:13 PM
  3. R80ST F wheel bearing
    By 70816 in forum Airheads
    Last Post: 03-22-2012, 03:33 AM
  4. Wheel Bearing Stack w/No Bearing
    By bostonmish in forum Airheads
    Last Post: 08-13-2010, 12:01 PM
  5. Front wheel bearing PM
    By twins4life in forum Oilheads
    Last Post: 08-16-2006, 01:40 PM
