I installed an ezcan and denali lights last night. When playing with all combinations I found that if I had the high beams on then shut the bike off the low beam bulb stayed on, then in 10 seconds the halos turned on. In 30 seconds both units shut off. Then I disconnected the denali lights but not the ezcan, shut the bike off with the brights on and the same thing happened. For the sake of science I should disconnect the ezcan then repeat the experiment, but it's too hot out. So I'm doing the next best thing, asking you guys if this is a design feature. I looked at the lighting section in the manual and it doesn't say anything about the feature. Talked with twisted throttle and they said it can't be the ezcan because it only listens to the canbus, amen never talks to the bike.
