Results 1 to 14 of 14
Thread: Photo Orientation?
    Mar 2012
    Riggins, ID
    Photo Orientation?
    Not sure what's changed but for some reason when I attach a photo to a forum post, it shows up upside down. In the past everything came in fine, right side up. Has something changed and how can I correct this? Thanks for your time.
    gp
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    Mansfield,MA
    It's not you
    We have been looking for a definitive reason and cure for this problem- talked about here- https://forums.bmwmoa.org/showthread...is-upside-down
    There have been a couple of threads but that one comes to mind. Wish I had a better answer for you.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Liaison 20774's Avatar
    Nothing has changed on this end that I know of. Likely there was an update to your phone's software that is now making this happen.
    Mar 2012
    Riggins, ID
    I had used the manage attachments in the past which worked fine. Per the link I tried the tree icon in the edit window with thw same results. There was a recent update of the IOS (10.3.2). Could be the problem. Not sure what to do about it.
    Gary -
    I'm not sure what the secret handshake is, but I believe that some amount of pre-rotation of the picture on the device or on your computer before uploading helps.
    Sep 2009
    Chestnut Hill, MA
    Gary -
    FWIW, I never upload photos to the Forum from the iPhone. I let them transfer to my MacBook Pro, make sure they're oriented correctly there, and then upload. Seems to work fine.
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    Mar 2012
    Riggins, ID
    Thanks all for your help. Haven't sorted it out yet but eventually will. Always do...
    gp
    Mar 2012
    Riggins, ID
    Your suggestion to rotate the photo before loading seems to be the ticket. Thanks again for the help. gp
    Jan 2016
    Central Illinois
    There should be a better solution than load picture on some other computer than rotate it some, might be right. The rotate button should be in the forum software
    Quote Originally Posted by 179212 View Post
    Sorry, but the forum software we're using is not being modified or updated anymore...only updated for security reasons. This is a problem with specific phones with specific operating systems. I'm pretty sure that any picture I've uploaded with my phone has never resulted in a rotated picture. Thus the issue has to be with the embedded information that is incorrectly being used on other phones/systems that is the problem. So, going forward, the user's will have to figure out how to "beat the system".
    Take the photo holding the phone rotated 180 degrees, or transfer to a computer and rotate the photo, or see if you can find an app that will rotate photos on the phone.
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Calgary AB
    +1 Yep, no matter what you will have to rotate - somehow. Annoying but doable.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Jan 2016
    Central Illinois
    Apple crap
    1st iPad photo landscape camera on left
    2nd portrait
    3rd landscape camera on right
    Jan 2016
    Central Illinois
    Seems like if you take picture with iPad 4 or iPhone 7 hold on side with camera on left pictures will post right would others try?
  1. fuel line orientation
    By 2slowwheels in forum Oilheads
    Last Post: 12-07-2016, 03:07 AM
  2. Orientation of Rocker supports?
    By Darryl Cainey in forum Airheads
    Last Post: 02-11-2014, 09:56 AM
  3. Rocker Arm Shaft Orientation '92 R 100 GS
    By brittrunyon in forum Airheads
    Last Post: 08-13-2013, 02:13 AM
  4. Air Snorkel Orientation
    By 20774 in forum Airheads
    Last Post: 03-05-2007, 11:09 PM
  5. R1150RT orientation
    By Oldbrit in forum Oilheads
    Last Post: 11-25-2003, 05:43 AM
